Cozmos
Post
by Cozmos » Wed Sep 07, 2016 1:27 pm
I'm creating a circular gauge in Xamarin forms, and I'm trying to change the label's color. I tried setting every property I could find, but it won't change... Can anyone help me?
this is my code: (just setting the property of the axis labels color here, because that's the one I think needs to be set... I also tried it with many other properties I found, but none are working).
Chart CreateView ()
var c = new Chart (this);
c.Header.Visible = false;
c.Panel.Visible = false;
var gauge = new CustomChart (c.Chart);
gauge.Frame.Visible = false;
gauge.FaceBrush.Visible = false;
gauge.DisplayTotalAngle = 180;
gauge.TotalAngle = 180;
gauge.Value = GetCurrentValue ();
gauge.Ticks.Visible = false;
gauge.Minimum = 0;
gauge.Maximum = GetMonths ();
gauge.Axis.Increment = GetMonths () / 4;
gauge.RedLine.Visible = false;
gauge.GreenLineStartValue = 0;
gauge.GreenLineEndValue = GetMonths ();
gauge.GreenLine.Gradient.Direction = Steema.TeeChart.Drawing.GradientDirection.LeftRight;
gauge.GreenLine.Gradient.StartColor = Color.FromRgb (6, 64, 137);
gauge.GreenLine.Gradient.EndColor = Color.FromHex ("#159DFB");
gauge.GreenLine.Pen.Visible = true;
gauge.Axis.Labels.Color = Color.Red;
return c;
In attachment the screenshot of my gauge, I want to change the color of the numbers on the axis
Thanks!
- Screen Shot 2016-09-07 at 15.26.10.png (28.68 KiB) Viewed 24412 times
- Guru
Post
by Christopher » Wed Sep 07, 2016 3:37 pm
Rather than Labels.Color, which is the color of the shape around the label (the shape is invisible by default), you should change the Label.Font characteristics, e.g.
gauge.Axis.Labels.Font.Color = Color.Red;
Cozmos
Post
by Cozmos » Thu Sep 08, 2016 9:50 am
I tried that too, and it isn't working either...
- Guru
Post
by Christopher » Thu Sep 08, 2016 10:36 am
The following code works as expected with TeeChart.dll, the Windows Forms version:
Func<int> GetCurrentValue = () =>
return 40;
Func<int> GetMonths = () =>
return 80;
CircularGauge gauge = new CircularGauge(tChart1.Chart);
gauge.Value = GetCurrentValue();
gauge.Minimum = 0;
gauge.Maximum = GetMonths();
gauge.Axis.Increment = GetMonths() / 4;
gauge.GreenLineEndValue = GetMonths();
gauge.GreenLine.Gradient.Direction = LinearGradientMode.ForwardDiagonal;
gauge.GreenLine.Gradient.StartColor = Color.FromArgb(255, 6, 64, 137);
gauge.GreenLine.Gradient.EndColor = Utils.HexToColor("FF159DFB");
gives me this:
- 636089349153306325.jpg (33.34 KiB) Viewed 24396 times
Which version of TeeChart are you using?
Cozmos
Post
by Cozmos » Thu Sep 08, 2016 10:50 am
I'm using the Xamarin Forms version: TeeChartXamarinFormsSource-4.0.2016.05310-osx (the newest release)
I tried it with your code, but still no success.
Post
by Pep » Thu Sep 08, 2016 4:26 pm
it's strange, I've just tested it here with the same version and it's working fine using :
gauge.Axis.Labels.Font.Color = Color.Blue;
or with another color.
Does this happens on both iOS and Android ?
