the export of a gantt to HTML5 seems not working well.
Export Gantt HTML5 JScript
- TeechartHtml5Gantt.zip
- (60.17 KiB) Downloaded 1239 times
Re: Export Gantt HTML5 JScript
I've reproduced the problem so I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1727
Thanks for reporting it.
thanks for your reply.
We look at the java script and we see that axes are inverted.
It seems not difficult to correct it. Do you think you could send us a patch?
It's very important for us, when do you think we can have a patch?
Hello Menant,
We aren't sure when you fix the problem. But, when we find a fix for it, we contact immediately with you.
Thanks in advance
Thanks in advance
You can get a copy of the calculated Axis Increment before exporting the Chart.
Eg.
The above code tests successfully with the example.
Eg.
procedure TForm4.Button1Click(Sender: TObject);
JavascriptExportFormat: TJavascriptExportFormat;
inherited;
Chart1.Axes.Bottom.Increment := Chart1.Axes.Bottom.CalcIncrement;
JavascriptExportFormat := TJavascriptExportFormat.Create;
JavascriptExportFormat.Panel := Chart1;
JavascriptExportFormat.CanvasName := 'canvas' + intToStr(Tag);
JavascriptExportFormat.JScript.SaveToFile('GanttTest.html');
