missing borders when copied and pasted
PKH
Post by PKH » Mon May 08, 2017 6:37 pm
In my program each chart has a "visible" border, with no bevels (chart/Panel/Borders/Border and /Bevels). I let the user copy a graph (for pasting into another document) using the following code:
chart1.CopyToClipboardMetafile(true);
However, the chart when pasted into a document has a border on only the bottom and right sides, not all four sides.
I recently upgraded to Berlin and the newest TeeChart. The same code when compiled using Delphi XE and an older version of TeeChart results in a chart (when pasted into a document) that has a border on all four sides.
Any suggestions?
Re: missing borders when copied and pasted
Post by Yeray » Tue May 09, 2017 7:11 am
PKH wrote: The same code when compiled using Delphi XE and an older version of TeeChart results in a chart (when pasted into a document) that has a border on all four sides.
Do you know what was the old "working" version. It could help us to find where the change was and why.
Post by Yeray » Tue May 09, 2017 7:37 am
I've just tested it with a new simple example project with just a TChart on a Form and a Button:
  Chart1.View3D:=False;
  Chart1.Border.Visible:=True;
  Chart1.Border.Width:=4;
  Chart1.BevelOuter:=bvNone;
  Chart1.BevelInner:=bvNone;
  Chart1.CopyToClipboardMetafile(True);
After clicking the button, I can paste the chart in a paint and in a Word/Writer document and I see the 4 borders:
I'm using TeeChart v2017.21. What version are you using?
PKH
Post by PKH » Tue May 09, 2017 1:12 pm
Thanks for the response. I am using Delphi Berlin 10.1 and TeeChart Pro v2016.19.161025.
Yes, if I increase the border width to 4 the copied and pasted chart does have four borders. But with lower border widths there are issues. I attached a zip file with a Delphi project to demonstrate.
In the program you can select the border width from 0 to 4. In the program, there clearly visible differences in the left and top borders versus the bottom and right borders. (Bevels are turned off.)
When you copy a chart with borderwidth=1 into Word or Powerpoint there is a border when the image is small, but the the left and top border disappear when the image is enlarged. I suspect that this effect has something to do with pixels, display resolution setting, and the particular program the image is pasted into.
For me, I must set the the borderwidth to 2 to get a border in the pasted image close to what I want.
Thanks again for your help.
GraphBorderIssue.zip
(65.36 KiB) Downloaded 1061 times
Post by Yeray » Tue May 09, 2017 2:03 pm
I've checked it with old versions and I always got the same result. However, GDI vs GDIPlus seems to make a difference here.
Note the default canvas moved to GDIPlus in newer versions. You can move back to GDI with:
uses TeCanvas;
  Chart1.Canvas:=TTeeCanvas3D.Create;
PKH
Post by PKH » Tue May 09, 2017 6:52 pm
I have both gdiplus.dll and qtintf70.dll in the same directory as the exe. I also include both when users download / install my software.
However, I notice no difference with gdi+ or without gdi+ in my test program. Should I continue to include gdi+ with my software?
Post by Yeray » Wed May 10, 2017 11:08 am
Here the project modified to check GDI and GDIPlus:
(2.09 KiB) Downloaded 1206 times
This is what I get with v2017.21 using a border width of 1:
Don't you get the same?
