typescript
samos
typescript
Post by samos » Mon May 29, 2017 9:19 am
Where can I find the updated typescript definition file?
thanks
Amos
Re: typescript
Post by Marc » Thu Jun 08, 2017 10:22 am
Hello Amos,
Apologies for the delay. I checked the typescript definition without noticing that it isn't included with the product files. That will be corrected. In the meantime the available plugin definitions are here:
https://www.steema.com/files/public/tee ... t/plugins/
samos
Re: typescript
Post by samos » Thu Jun 08, 2017 10:40 am
This is old definition from 2012.
In the release notes of 1.9 you had mention that you updated the Typescript definition file.
9. [No ID] - TypeScript Definition file updated to TeeChart v1.9.
Amos
Re: typescript
Post by Marc » Fri Jun 09, 2017 2:34 pm
Hello Amos,
Thanks for the feedback. We've corrected the uploaded version, sorry for the mistake.
View here: https://www.steema.com/files/public/tee ... ypeScript/
Download here: https://www.steema.com/files/public/tee ... Script.zip
samos
Re: typescript
Post by samos » Mon Jun 12, 2017 7:47 am
There are some problems with the teechart.d.ts
For example using of bool instead of boolean,
bounds property in IGantt is not the same as in ISeries
remove path="lib/lib.d.ts" no need for that.
Also I added some properties and constructors.
remove some places the declare statement.
let me know if you ant me to upload it here or send it to you.
Amos
Re: typescript
Post by Yeray » Mon Jun 12, 2017 8:22 am
Hello Amos,
You can send the file to "info at steema dot com" and we'll be glad to look at your changes and incorporate them to the production version!
Thanks!
Re: typescript
Post by Marc » Mon Jun 12, 2017 3:20 pm
Thanks for the input Amos, your modifications have been incorporated.
