How to get reasonable X axis markers
UliBru
Post by UliBru » Sun Jun 11, 2017 6:30 am
I need to create charts with a logarithmic x axis. Furthermore it is necessary to zoom into the charts.
This leads to strange x axis markers and ticks.
Some examples:
So how to control the appearance of major, minor ticks and text with different zoom states?
Is there a function for this or is it necessary to draw the x axis by a custom function?
What is a good strategy to get nice and reasonable text markers for a zoomed picture?
Thanks for help
- Uli
Re: How to get reasonable X axis markers
Post by Yeray » Mon Jun 12, 2017 8:15 am
This seems to work as expected for me here:
uses Series;
var i: Integer;
  Chart1.View3D:=False;
  Chart1.Legend.Visible:=False;
  Chart1.Axes.Bottom.Logarithmic:=True;
  with Chart1.AddSeries(TLineSeries) as TLineSeries do
    Pointer.Visible:=True;
    Pointer.Size:=2;
    for i:=1 to 11 do
        AddXY(exp(i), i);
However, the bottom axis labels overlap if you put more values into that series. This depends on the chart width but I get overlapping axis labels with 23 values.
http://bugs.teechart.net/show_bug.cgi?id=1879
I haven't found extra problems when zooming the chart though.
It would be helpful of you could arrange a simple example we could run as-is to reproduce the problem here.
UliBru
Post by UliBru » Mon Jun 12, 2017 12:03 pm
Hello Yeroay,
thanks, I'll prep some example code.
In the meantime I have also detected that the appearance of the x axis labes also depends on the window size. So resizing the application window changes the labels.
And this also leads to a problem as even if the desktop window may nicely show up the labels the export of the chart with smaller sizes for documentation will result in pictures with modified labels. And this result is unpredictable from the user point of view.
Beside this there must also be a bug. I will prep some pictures.
Best regards
Uli
UliBru
Post by UliBru » Wed Jun 14, 2017 9:21 am
Hello Yeray,
I have done some further tests.
The devil is given by Chart.BottomAxis.Increment. By default the value is 0 and we get x axis labels at positions 1, 10, 100, 1000 ...
If the value is changed to 1 then we get x axis labes at 1000, 2000, 3000 ... But if the chart is zoomed the labels can overlap.
Dragging a window corner to resize the window even shows up the x axis labels jumping between different visualizations.
So a solution is to always use Chart.BottomAxis.Increment := 0. As this is a default value where it makes sense to NEVER TOUCH it!
Now I have still one question (based on a minor tick number of 8):
Is it possible to create x axis labes e.g. in sequence 1, 5, 10, 50, 100, 500, 1000, 5000, 10000 ... ??
And finally there is still a bug with zoom:
So if you e.g. create a chart with logarithmic x axis from 1 to 10000 and you zoom into the chart from 150 to 10000 the minor ticks below 1000 get lost.
See the picture, where 8 minor ticks are missed. So there is no chance to estimate the x axis position according to a given curve point:
Best regards
Uli
Post by Yeray » Thu Jun 15, 2017 8:24 am
Hello Uli,
UliBru wrote:I have done some further tests.
Sounds as the request in #890 but you you could try using custom labels as follows:
uses Series, Math;
var i: Integer;
  Chart1.Align:=alClient;
  Chart1.Legend.Hide;
    Pointer.Show;
    Pointer.Size:=2;
    for i:=0 to 10 do
       AddXY(exp(i), i);
  Chart1.Axes.Bottom.Increment:=1;
  Chart1.Axes.Bottom.Items.Clear;
  for i:=0 to 5 do
    Chart1.Axes.Bottom.Items.Add(power(10, i), FormatFloat('#,##0.##', power(10, i)));
    Chart1.Axes.Bottom.Items.Add(power(10, i)*5, FormatFloat('#,##0.##', power(10, i)*5));
UliBru wrote:And finally there is still a bug with zoom:
This sounds as the ticket #1388. Feel free to add your mail to the Cc list to be automatically notified when an update arrives.
UliBru
Post by UliBru » Sun Jun 18, 2017 3:50 pm
Yeray,
thanks.
1)
I'll study on using the custom labels. At first look it is ok, but in combination with zooming this may be tricky. Because I may need to design custom labels for each zoom situation.
2)
I have cc'd to the bug list regarding the minor ticks display bug
BR
Uli
UliBru
Post by UliBru » Tue Jun 20, 2017 2:25 pm
Hello Yeray,
after struggling around with switching linear and logarithmic x-axis including zooming I have now come to the following solution:
  i, j: integer;
  maxx, minx, Position: Double;
  Chart: TChart;
  Chart := TChart(Sender);
  maxx := Chart.BottomAxis.Maximum;
  minx := Chart.BottomAxis.Minimum;
  if maxx = minx then
    exit;
  if Chart.BottomAxis.Logarithmic then
    for i := -1 to 5 do
      for j := 2 to 9 do
        Position := Power(10, i) * j;
        if (Position >= minx) and (Position <= maxx) then
          DrawMinorTick(Chart, Power(10, i) * j);
procedure TForm1.Chart1BeforeDrawAxes(Sender: TObject);
  i: integer;
  maxx, minx: Double;
  Chart: TChart;
  if maxx = minx then
    exit;
  Chart.Axes.Bottom.Items.Clear;
    Chart.BottomAxis.MinorTickCount := 0;
    if (minx > 0.1) and (maxx < 1) or (minx > 1) and (maxx < 10) or (minx > 10) and (maxx < 100) or (minx > 100) and
      (maxx < 1000) or (minx > 1000) and (maxx < 10000) or (minx > 10000) and (maxx < 100000) or (minx > 100000) and
      (maxx < 1000000) then
      Chart.Axes.Bottom.Items.Add(minx, Format('%1.0f', [minx]));
      Chart.Axes.Bottom.Items.Add(maxx, Format('%1.0f', [maxx]));
    end
      for i := -1 to 5 do
        Chart.Axes.Bottom.Items.Add(Power(10, i), Format('%1.0f', [Power(10, i)]));
//        Chart.Axes.Bottom.Items.Add(Power(10, i) * 5, Format('%1.0f', [Power(10, i) * 5]));
      if (minx <> 0.1) and (minx <> 1) and (minx <> 10) and (minx <> 100) and (minx <> 1000) and (minx <> 10000) and
        (minx <> 100000) then
      if (maxx <> 0.1) and (maxx <> 1) and (maxx <> 10) and (maxx <> 100) and (maxx <> 1000) and (maxx <> 10000) and
        (maxx <> 100000) then
  end
  else // linear axis
    Chart.Axes.Bottom.Items.Automatic := true;
    Chart.BottomAxis.MinorTickCount := 3;
So the solution shows the labels in Power10 steps. If you zoom in and a power10 label is still there it will be shown. In addition the chart now also displays the lowest and highest x value. So if you zoom more into the chart at least min and max x value are displayed as label.
Furthermore the minor ticks are custom drawn and thus are correct for each zoom state. The reported bug is at least also solved by this approach.
Also the export e.g. to PNG now properly works.
So maybe you can benefit a little from my example.
Best regards
Uli
Post by Yeray » Wed Jun 21, 2017 8:11 am
Hello Uli,
Thanks for the code! I've added a link to it in the #1388 ticket.
UliBru
Post by UliBru » Wed Jun 21, 2017 2:56 pm
Hello Yeray,
I have refined the code for correctness, speed and clarity.
It contains some specialties as a user can zoom into between the major ticks. The minor ticks are still shown, the chart ends show labels to inform about the x axis values.
If there is a major label too close to a chart end the according end label is not displayed.
  i: integer;
  maxx, minx, tickpos, tickposx: Double;
  Chart: TChart;
  procedure DrawMinorTick(value: Double);
    xpos, ypos: integer;
    Chart.Canvas.Pen.Color := Chart.BottomAxis.MinorTicks.Color;
    Chart.Canvas.Pen.Width := Chart.BottomAxis.MinorTicks.Width;
    Chart.Canvas.Pen.Style := Chart.BottomAxis.MinorTicks.Style;
    xpos := Chart.BottomAxis.CalcPosValue(value);
    ypos := Chart.BottomAxis.PosAxis + 1;
    Chart.Canvas.Line(xpos, ypos, xpos, ypos + Chart.BottomAxis.MinorTickLength);
  if maxx = minx then // chart may be empty
    exit;
    tickpos := 0.01;
    repeat
      for i := 2 to 9 do // = 8 minor ticks
        tickposx := tickpos * i;
        if tickposx < minx then
          continue;
        if tickposx > maxx then
          break;
        DrawMinorTick(tickposx);
      tickpos := tickpos * 10;
    until tickposx > maxx;
  maxx, minx, xpos, minlabelpos, maxlabelpos: Double;
  inbetween: Boolean;
  Chart: TChart;
  procedure AddXLabel(xpos: Double);
    if (xpos >= 1) then
      Chart.Axes.Bottom.Items.Add(xpos, Format('%1.0f', [xpos]))
    else if (xpos >= 0.1) then
      Chart.Axes.Bottom.Items.Add(xpos, Format('%1.1f', [xpos]))
      Chart.Axes.Bottom.Items.Add(xpos, Format('%1.2f', [xpos]));
  procedure AddMinMaxXLabel(xpos: Double);
    if (xpos >= 10) then
    else if (xpos >= 1) then
    exit;
    Chart.BottomAxis.MinorTickCount := 0; // clear automatic minor ticks, custom draw in OnBeforeAxes
    // check for absence of major ticks
    xpos := 0.01;
    inbetween := false;
    repeat
      if ((minx > xpos) and (maxx < xpos * 10)) then
        inbetween := true;
      xpos := xpos * 10;
    until xpos > maxx;
    if inbetween then // no major ticks
      AddMinMaxXLabel(minx);
      AddMinMaxXLabel(maxx);
    end
      // draw major ticks + labels
      minlabelpos := 1000000;
      maxlabelpos := 0;
      xpos := 0.01;
      repeat
        if (xpos >= minx) then
          if xpos > maxx then
            break;
          AddXLabel(xpos);
          // AddXLabel(Position*5);
          if xpos < minlabelpos then // memorize minlabel
            minlabelpos := xpos;
          if xpos > maxlabelpos then // memorize maxlabel
            maxlabelpos := xpos;
        xpos := xpos * 10;
      until xpos > maxx;
      // possibly draw labels at chart ends
      if minx <= 0.9 * minlabelpos then
      if maxx >= 1.2 * maxlabelpos then
  end
  else // linear axis
Have fun :)
Uli
Post by Yeray » Thu Jun 22, 2017 6:24 am
Thanks for sharing, Uli!
