Scale axes to shown data
RJRJ
Post by RJRJ » Thu Dec 14, 2017 3:24 pm
Hi, I want to create an option where with one checkbox it is possible to see last 20 minutes of the graph.
I started with
  // Graph settings
  if CheckBoxGraphsLast20m.Checked then
    with ChartRaw.BottomAxis do
        Automatic := False;
        AutomaticMaximum := True;
        AutomaticMinimum := False;
        Minimum := Now-(5/86400);   // 5 secs
      end
    ChartRaw.BottomAxis.Automatic := true;
But when the checkbox is checked,
Y axes do not scale to the visible data points but keep the range concerning the full data set
Which properties/methods should I look into the get the basic effect of only showing the last x minutes of data?
Re: Scale axes to shown data
Post by Yeray » Fri Dec 15, 2017 2:27 pm
Here it is a simple example showing how to do what I understand you are trying to achieve:
uses Series, Math;
const nLastPointsToShow=10;
const oneSecond=1.0/86400.0;
var i: Integer;
    tmp: Double;
const initValues=100;
  Chart1.View3D:=False;
  Chart1.Legend.Visible:=False;
  with Chart1.AddSeries(TFastLineSeries) do
    XValues.DateTime:=True;
    tmp:=Now;
    AddXY(tmp-(oneSecond*initValues), 100+random*10);
    for i:=initValues-1 downto 0 do
      AddXY(tmp-oneSecond*i, YValue[Count-1] + random*10-5);
  Chart1.Axes.Bottom.LabelStyle:=talPointValue;
  Chart1.Axes.Bottom.LabelsAngle:=90;
  Chart1.Axes.Bottom.DateTimeFormat:='hh:mm:ss';
  Timer1.Interval:=1000;
  Timer1.Enabled:=True;
procedure TForm1.Timer1Timer(Sender: TObject);
  with Chart1[0] do
    AddXY(Now, YValue[Count-1] + random*10-5);
  CheckAxes;
procedure TForm1.CheckAxes;
var i: Integer;
    tmpMax, tmpMin: Double;
  if CBShowLast.Checked then
    Chart1.Axes.Bottom.AutomaticMinimum:=False;
    with Chart1[0] do
      Chart1.Axes.Bottom.Minimum:=XValue[Count-nLastPointsToShow];
      Chart1.Repaint;
      tmpMin:=YValue[FirstDisplayedIndex];
      tmpMax:=YValue[FirstDisplayedIndex];
      for i:=Chart1[0].FirstDisplayedIndex+1 to Chart1[0].LastDisplayedIndex do
        tmpMin:=Min(tmpMin, YValue[i]);
        tmpMax:=Max(tmpMax, YValue[i]);
    Chart1.Axes.Left.SetMinMax(tmpMin, tmpMax);
  end
    Chart1.Axes.Bottom.Automatic:=True;
    Chart1.Axes.Left.Automatic:=True;
procedure TForm1.CBShowLastClick(Sender: TObject);
  CheckAxes;
RJRJ
Post by RJRJ » Mon Dec 18, 2017 11:12 am
Thanks for the help.
I have one shared standard bottom ax and three custom Y-axes on the right. I do not fully understand the code because I had no time to read the docs (got to run to airport now), but it seems to work.
procedure TFormCoultCell2.CheckAxes(const aChart: TChart; const nLastPointsToShow: Cardinal);
  I, Ax: Integer;
  // 0 and 1 give full scale
  if (nLastPointsToShow > 1) and (aChart.Series[0].Count > nLastPointsToShow) then
      aChart.Axes.Bottom.AutomaticMinimum:=False;
      with aChart[0] do // Refers to ?
        aChart.Axes.Bottom.Minimum:=XValue[max(0, Count-nLastPointsToShow)];
        aChart.Repaint;
      // Loop all custom axes (they're all Y-axes on right, sharing standard bottom axe)
      for Ax := 0 to aChart.CustomAxes.Count-1 do
          for I:=aChart[Ax].FirstDisplayedIndex+1 to aChart[Ax].LastDisplayedIndex do
        aChart.Axes[Ax].SetMinMax(tmpMin, tmpMax);
    end
      aChart.Axes.Bottom.Automatic:=True;
        aChart.CustomAxes[Ax].Automatic := true;
Post by Yeray » Mon Dec 18, 2017 2:53 pm
Note aChart[0] gives the first series in the Chart. So in your case, where you seem to have one series assigned to each custom axis, you should calculate the tmpMin and tmpMax using aChart[Ax] YValue. Ie:
  I, Ax: Integer;
      with aChart[0] do // Assuming all the series have the same number of XValues
        aChart.Repaint;
          tmpMin:=aChart[Ax].YValue[aChart[Ax].FirstDisplayedIndex];
          tmpMax:=aChart[Ax].YValue[aChart[Ax].FirstDisplayedIndex];
            tmpMin:=Min(tmpMin, aChart[Ax].YValue[i]);
            tmpMax:=Max(tmpMax, aChart[Ax].YValue[i]);
    end
RJRJ
Post by RJRJ » Wed Dec 27, 2017 10:16 am
OK this is what I ended up with.
I have one standard shared X axis, 3 custom Y axes, some of which may or may not have data.
  I, S, Ax: Integer;
  if (nLastPointsToShow > 1) and (aChart[0].Count-nLastPointsToShow > 0) then
      with aChart[0] do // Refers to first normal series, all series have same X-data, if data lacks, will have Y=Null
        aChart.Repaint;
      // Loop each series
      for S := 0 to aChart.SeriesCount-1 do
          tmpMin := high(integer);
          tmpMax := low(integer);
          // If the series have positive amount of points
          if (aChart[S].YValues.Count > nLastPointsToShow) then
              // Loop the last n points and get min and max
              for I := (aChart[S].YValues.Count-1) downto (aChart[S].YValues.Count -nLastPointsToShow) do
                  tmpMin:=Min(tmpMin, aChart[S].YValue[I]);
                  tmpMax:=Max(tmpMax, aChart[S].YValue[I]);
              // Turn of automatic and apply min and max
              aChart[S].CustomVertAxis.AutomaticMinimum := false;
              aChart[S].CustomVertAxis.AutomaticMaximum := false;
              aChart[S].CustomVertAxis.Maximum := tmpMax;
              aChart[S].CustomVertAxis.Minimum := tmpMin;
    end
  // Set bottom and all customs to auto
RJRJ
Post by RJRJ » Fri Dec 29, 2017 3:46 pm
How is it that with
              if tmpMax >= tmpMin then
                  aChart[S].CustomVertAxis.Minimum := tmpMin;   // This one
I get AxisException: 'Axis Maximum Value must be >= Minimum'.
Will remove the = from comparison. I added other things as well, but I still get the same exception.
              if (tmpMax > tmpMin) and (assigned(aChart[S].YValues)) and (aChart[S].YValues.Count > 0) then
PS. There is a serie and axis without any data, plus 3 series and 2 axes with data.
Post by Marc » Tue Jan 02, 2018 12:20 pm
Likely at the moment that the Maximum is being set it is less than the Minimum (the actual value of Minimum at the moment you're trying to set Maximum). You could check that and set Minimum first or use:
  aChart[S].CustomVertAxis.SetMinMax(tmpMin,tmpMax);
Post by Sandra » Tue Jan 02, 2018 12:52 pm
Hello RJRJ,
To complete the Marc's explanation, you find a simple example below:
uses Series, Math;
var i,t: Integer;
    tmp: Double;
    tmp:=Now;
    tmp:=Now;
    tmp:=Now;
  Chart1.Draw();
  Chart1.Axes.Left.StartPosition := 0;
  Chart1.Axes.Left.EndPosition := 30;
  Chart1[0].VertAxis := aLeftAxis;
  Chart1[1].CustomVertAxis := Chart1.CustomAxes[0];
  Chart1[2].CustomVertAxis := Chart1.CustomAxes[1];
  Chart1.CustomAxes[0].StartPosition := 30;
  Chart1.CustomAxes[0].EndPosition := 60;
  Chart1.CustomAxes[0].Axis.Color := clRed;
  Chart1.CustomAxes[1].StartPosition := 60;
  Chart1.CustomAxes[1].EndPosition := 100;
  Chart1.CustomAxes[1].Axis.Color := clBlue;
  with Chart1[0] do
  with Chart1[1] do
  with Chart1[2] do
  CheckAxes(Chart1,nLastPointsToShow);
procedure TForm1.CheckAxes(const aChart: TChart; const nLastPointsToShow: Cardinal);
  I, Ax: Integer;
        aChart.Repaint;
          tmpMin:=aChart[Ax+1].YValue[aChart[Ax+1].FirstDisplayedIndex];
          tmpMax:=aChart[Ax+1].YValue[aChart[Ax+1].FirstDisplayedIndex];
          for I:=aChart[Ax+1].FirstDisplayedIndex+1 to aChart[Ax].LastDisplayedIndex do
            tmpMin:=Min(tmpMin, aChart[Ax+1].YValue[i]);
            tmpMax:=Max(tmpMax, aChart[Ax+1].YValue[i]);
    end
Thanks in advance
