VB6 code for loading the ESRI line and point shp file
SPR
Post by SPR » Thu Jan 18, 2018 3:09 pm
Hi, Yeray,
I am a newbie in Teechart Map series. I learned the examples provided with the installed AX (Tchart7.ocx) how to load the ESRI shp with the tchart Map series in VB6, and the example code you provided can load only the polygon file. Could you provide more codes in VB6 for adding the line and point shp files?
Looking forward to receiving your support.
Re: VB6 code for loading the ESRI line and point shp file
Post by Yeray » Tue Jan 23, 2018 8:49 am
Could you please send us some shp files with lines and points we could use to test it?
SPR
Post by SPR » Fri Jan 26, 2018 3:21 am
Thanks Yeray for your reply. What I meant is a polylines shp file. I learned in your VB sample source code, it mentioned case polyline but did not provide codes for it.
Best regards
Post by Yeray » Fri Jan 26, 2018 3:12 pm
SPR wrote:What I meant is a polylines shp file
Do you have one we can use to test it?
SPR
Post by SPR » Fri Jan 26, 2018 3:40 pm
Dear Yeray
Please find attached the zip file, which comprises of 3 files: shp; shx and dbf.
Best regards
Sopharith
mainstream.zip
(87.77 KiB) Downloaded 1129 times
SPR
Post by SPR » Fri Jan 26, 2018 3:59 pm
Dear Yeray,
I would like to send you the new file in Latlong (degree). The recent sent is in UTM in metres.
Best regards,
mainstreams_LL.zip
(83.37 KiB) Downloaded 1109 times
Post by Marc » Fri Feb 09, 2018 10:13 am
We are adding a new method to Map Series to load the map directly from filename. The method will be available with the next update, ready within the next few days.
SPR
Post by SPR » Sun Feb 11, 2018 4:16 pm
Thanks Marc. Looking forward to receiving the update.
Best regards,
Sopharith
