I have a chart plotting a line series but when I add a HighLow series the Legend and Annotation tool are blanked out.
I've just updated to version 2018.25 from 2017.21, so this bug has been introduced since then.
Sean.
THighLowSeries and Legend drawing problem?
- Normal Chart showing Line Series
- 2018-10-18_14-37-17.jpg (60.53 KiB) Viewed 10014 times
- Chart with line and HighLow Series showing blanked Legend & Annotation
- 2018-10-18_14-35-58.jpg (55.08 KiB) Viewed 10014 times
Re: THighLowSeries and Legend drawing problem?
I could reproduce the problem so I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=2116
This is just to inform I have been able to fix the bug (#2116) so the next release will include it.
If you want to fix it in your sources, you just have to add this line at the end of the THighLowSeries.DoBeforeDrawValues method, in ErrorBar.pas:
Procedure THighLowSeries.DoBeforeDrawValues;
ParentChart.Canvas.UnClipRectangle;
Thanks for fixing this so quickly.
Sean.
Sean.
