TeeChart VCL/FMX 2018.26 Install in Rio
Re: TeeChart VCL/FMX 2018.26 Install in Rio
Post by Yeray » Wed Dec 12, 2018 11:56 am
Hello Dirk,
We are preparing the binary installers but I'm afraid the process takes hours and hours to compile everything for all the versions supported.
We'll publish them asap.
D.R. wrote:
Wed Dec 12, 2018 10:41 am
or is it possible to to install both at the same time?
I'm not sure to understand what you mean here.
I have tens of installs done in this machine, some are binary, some with sources, some standard, some pro,...
Then, when I want to install a version to an IDE I "only" have to run the according TeeInstall.exe and correct the paths when it has finished.
Post by Yeray » Wed Dec 12, 2018 2:09 pm
This is to inform we've just finished uploading the fixed binary versions replacing the broken ones.
So the download page should give working installers for all.
D.R.
Post by D.R. » Wed Dec 12, 2018 4:57 pm
Dear Yeray,
that's what I wanted to know,
I never did paralell installation before.
All installers are running fine now, so problem
seems to be solved.
On my opinion you can mark [Bug 2130] as fixed,
there have been no more problems during installation.
Many thanks for your great job fixing problems quickly.
Sincerly
Dirk
Post by Yeray » Thu Dec 13, 2018 9:02 am
Hello Dirk,
Thanks for the feedback. I've just closed the ticket #2130
Post by » Fri Dec 14, 2018 11:19 am
On the download page the date of the binary installer for TeeChartVCLFMX-2018.26.exe is 7 December which predates the fix date.
Post by Yeray » Mon Dec 17, 2018 7:28 am
We completely replaced the installers we initially released for v2018.26 without touching anything else than that fix. Ie, the release.txt whipped with the installer also indicates the old date.
I'll modify the download date, even if it will be unsync with the date in the release.txt.
