johnnix
Post
by johnnix » Mon Apr 08, 2019 9:04 am
I believe this question was asked many years ago but I could not retrieve anything from Search.
I need to fill the area between 2 series (e.g. Series1 and Series2) with a constraint that fill will apply only when Series1 values are smaller than Series 2 (see attached image), I tried using the available TChart tools but with no luck, any help would be mostly appreciated
- Annotation 2019-04-08 120016.png (5.35 KiB) Viewed 20456 times
Post
by Yeray » Mon Apr 08, 2019 11:25 am
Check the Series Band Tool. I've just run the "All features\Welcome !\Tools\Series Band" example in the New Features demo, changed the series from Line series to HorizLine series and reassigned the second series for the tool:
- Tee9new_2019-04-08_13-23-26.png (177.39 KiB) Viewed 20451 times
johnnix
Post
by johnnix » Mon Apr 08, 2019 12:35 pm
I tried that, had to change both line series to Horizontal type however the result is not good.
- Annotation 2019-04-08 152955.png (4.58 KiB) Viewed 20448 times
Post
by Yeray » Tue Apr 09, 2019 8:24 am
Please, arrange a simple example project we can run as-is to reproduce the problem here.
johnnix
Post
by johnnix » Tue Apr 09, 2019 2:33 pm
Here is a sample app
- test.zip
- (51.92 KiB) Downloaded 1283 times
Post
by Yeray » Thu Apr 11, 2019 11:27 am
I could reproduce the problem so I've added it tot he public tracker:
#2182.
Note I've already fixed it.
The fix consists on modifying the TryAddCrossPoint function in TeeSeriesBandTool.pas, from this:
function TryAddCrossPoint(t:Integer; isStairs,isStairs2:Boolean):Boolean;
if result then
AddPointXY(Series.CalcXPosValue(X),Series.CalcYPosValue(Y))
end
if IsStairs then
AddPoint(Series,IsStairs,t);
To this:
if result then
if Series.YMandatory then
AddPointXY(Series.CalcXPosValue(Y),Series.CalcYPosValue(X));
end
if IsStairs then
johnnix
Post
by johnnix » Thu Apr 11, 2019 1:10 pm
Thank you, will give it a try
