Error installing OSX64 v26 with TeeChart Source Code Recompilation Tool
chartist
Post by chartist » Tue Nov 19, 2019 1:01 pm
I encountered an error when installing the latest TeeChart VCL, into a clean copy of Windows 7 and a fresh install of RAD Studio 10.3.2 Rio.
The compilation failed for Mac OSX64, as you can see here:
Steema Install Error.png (56.39 KiB) Viewed 14146 times
The log file says:
Mac OSX64 v26 (Delphi 10.3 and C++Builder 10.3 Update 2)
FMXTee926
Cannot recompile Delphi package: FMXTee926.dpk
Embarcadero Delphi Next Generation for Mac OS X 64 bit compiler version 33.0
Copyright (c) 1983,2018 Embarcadero Technologies, Inc.
Linker command line: "C:\Program Files (x86)\Embarcadero\Studio\20.0\bin\ld.exe" -arch x86_64 -o "C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2019.28\Source\..\Compiled\Delphi26.osx64\System\bplFMXTee926.dylib" -map "C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2019.28\Source\..\Compiled\Delphi26.osx64\System\bplFMXTee926.dylib.map" -e __ZN9Fmxtee92614initializationEv -dead_strip -dead_strip_dylibs -mark_dead_strippable_dylib -exported_symbols_list "C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2019.28\Source\..\Compiled\Delphi26.osx64\System\FMXTee926.exp" -dylib -export_dynamic -macosx_version_min 10.8 -F \System\Library\Frameworks -F \System\Library\PrivateFrameworks -L "C:\Program Files (x86)\Embarcadero\Studio\20.0\Lib\osx64\Debug" -L "C:\Program Files (x86)\Embarcadero\Studio\20.0\Redist\osx64" -L "C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2019.28\Source\FMX" -rpath $ORIGIN -install_name @rpath/bplFMXTee926.dylib -filelist "C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2019.28\Source\..\Compiled\Delphi26.osx64\System\FMXTee926.lnk"
Error: E2597 ld: warning: directory not found for option '-L/usr/lib'
 ld: warning: directory not found for option '-F\System\Library\Frameworks'
 ld: warning: directory not found for option '-F\System\Library\PrivateFrameworks'
 ld: warning: directory not found for option '-F/System/Library/Frameworks/'
 ld: file not found: /usr/lib/libiconv.dylib
Fatal: F2588 Linker error code: 1 ($00000001)
EXCEPTION:
Compilation aborted.
Any thoughts on what could be happening here?
Re: Error installing OSX64 v26 with TeeChart Source Code Recompilation Tool
Post by Yeray » Fri Nov 22, 2019 12:37 pm
Could you please configure a MacOS64 platform SDK in your IDE and give it another try?
Coniah
Post by Coniah » Thu Jan 02, 2020 3:53 pm
I am also having trouble installing the OSX64 version of TeeChart. I am getting the following error whenever I try to install it using the Recompile tool. I am able to compile and run an OSX64 program without the TeeChart component. What do I need to do to fix this? I get other errors when installing the BI and TeeGrid OSX64 components. The other ones (Win32, Win64, OSX32, iOS 64bit, Android 64bit, etc.) install without errors.
TeeChart Pro
Compilation started: 2020-01-02 7:42:48 AM
Mac OSX64 v26 (Delphi 10.3 and C++Builder 10.3 Update 3)
FMXTee926
Linker command line: "C:\Program Files (x86)\Embarcadero\Studio\20.0\bin\ld.exe" -arch x86_64 -o "C:\Program Files (x86)\Steema Software\Steema TeeSuite Pro 2019 for RAD Studio 2019.11.06\Components\TeeChart Pro VCL FMX\Source\..\Compiled\Delphi26.osx64\System\bplFMXTee926.dylib" -e __ZN9Fmxtee92614initializationEv -dead_strip -dead_strip_dylibs -mark_dead_strippable_dylib -exported_symbols_list "C:\Program Files (x86)\Steema Software\Steema TeeSuite Pro 2019 for RAD Studio 2019.11.06\Components\TeeChart Pro VCL FMX\Source\..\Compiled\Delphi26.osx64\System\FMXTee926.exp" -dylib -export_dynamic -S -x -macosx_version_min 10.8 -syslibroot C:\Users\Coniah\Documents\Embarcadero\Studio\SDKs\MacOSX10.15.sdk -F C:\Users\Coniah\Documents\Embarcadero\Studio\SDKs\MacOSX10.15.sdk\System\Library\Frameworks -F C:\Users\Coniah\Documents\Embarcadero\Studio\SDKs\MacOSX10.15.sdk\System\Library\PrivateFrameworks -L "C:\Program Files (x86)\Embarcadero\Studio\20.0\Lib\osx64\Release" -L "C:\Program Files (x86)\Embarcadero\Studio\20.0\Redist\osx64" -L "C:\Program Files (x86)\Steema Software\Steema TeeSuite Pro 2019 for RAD Studio 2019.11.06\Components\TeeChart Pro VCL FMX\Source\FMX" -rpath $ORIGIN -install_name @rpath/bplFMXTee926.dylib -filelist "C:\Program Files (x86)\Steema Software\Steema TeeSuite Pro 2019 for RAD Studio 2019.11.06\Components\TeeChart Pro VCL FMX\Source\..\Compiled\Delphi26.osx64\System\FMXTee926.lnk"
Error: E2597 Undefined symbols for architecture x86_64:
Error: "__ZN3Fmx8Platform3Mac10TFMXWindowv04cdtrEv", referenced from: __ZN9Fmxtee9260E in FMXTee926.o;
Error: "__ZN3Fmx8Platform3Mac10TFMXWindowv04cctrEv", referenced from: __ZN9Fmxtee9260E in FMXTee926.o;
ld: symbol(s) not found for architecture x86_64
EXCEPTION:
Post by Yeray » Wed Jan 08, 2020 12:26 pm
I've replied you here.
