Annotations do not render. Steema.TeeChart.NET.Xamarin.Forms v4.2021.2.25
TLC
Post by TLC » Mon Mar 22, 2021 2:59 am
Annotation Tool Popup doesn't respect placements. Width and Height are both zero, but the bounds show correct sizing. It always renders off the screen, no matter what placement ( left ( x ), top ( y ) ) I set it to.
What is displayed:
Current settings with the above view:
Previous possible related issue
TLC
Re: Annotation Tool Popup doesn't respect placements.
Post by TLC » Mon Mar 22, 2021 2:52 pm
This occurs on both android and iOS.
TLC
Post by TLC » Mon Mar 22, 2021 4:28 pm
private void Setup()
		AnnotationTool = new Annotation(Chart1)
							 Active = true,
							 Position = AnnotationPositions.Custom,
							 Text = ViewModel.SelectedItemDescription,
							 AutoSize = true,
							 TextAlign = TextAlignment.Start,
							 AllowEdit = false
	// AnnotationTool.CoerceVisibleAnnotation(Chart1.ChartBounds, Chart1.Title.ShapeBounds, ViewModel.AnnotationHeightOffset);
	public static void CoerceVisibleAnnotation( this Annotation tool, in Rectangle chart, in Rectangle title, in double offset )
		Rectangle startBounds = tool.Bounds;
		double width = tool.Width;
		double height = tool.Height;
		if ( tool.Bounds.Right > chart.Right ) { tool.Left = chart.Right - width - offset; }
		if ( tool.Left <= chart.Left ) { tool.Left = offset; }
		if ( tool.Top <= title.Bottom ) { tool.Top = title.Bottom + offset; }
		if ( tool.Bounds.Bottom >= chart.Bottom ) { tool.Top = chart.Bottom - height - offset; }
Post by Pep » Tue Mar 23, 2021 6:10 am
please, take a look at this post, because most likely the problem is caused by the object positioning over the Chart, and here you will find how position must be calculated.
TLC
Post by TLC » Tue Mar 23, 2021 6:17 pm
Yes, I do that to find the target point. If you notice, the arrow points to the selected point. The issue is the annotation; It is not being rendered at all. I tried to center it regardless of what point is chosen.
public static class ChartExtensions
	public static double GetLocalMaximum( this Line line, bool isVertical )
		var max = double.MinValue;
		//for (int i = 0; i < line.Count; i++)
		for ( int i = line.FirstVisibleIndex; i <= line.LastVisibleIndex; i++ )
			double v = isVertical
						   ? line.CalcYPos(i)
						   : line.CalcXPos(i);
			max = Math.Max(max, v);
		return max;
	public static double GetLocalMinimum( this Line line, bool isVertical )
		var min = double.MaxValue;
						   ? line.CalcYPos(i)
						   : line.CalcXPos(i);
			min = Math.Min(min, v);
		return min;
	public static double LocalAveragePos( this Line line, out double min, out double max, bool vertical )
		min = line.GetLocalMinimum(vertical);
		max = line.GetLocalMaximum(vertical);
		return Average(min, max);
	public static void ConfigureAnnotations( this Annotation tool, bool floating, string text )
		tool.Shape.TextFormat = TextFormat.Html;
		tool.Shape.Font.Size = 15;
		tool.Position = floating
							? AnnotationPositions.Custom
							: AnnotationPositions.RightTop;
		tool.Text = text;
		tool.AutoSize = true;
		tool.Active = !string.IsNullOrWhiteSpace(text);
		tool.Invalidate();
	public static double AverageWidth( this Rectangle bounds ) => Average(bounds.Left, bounds.Right);
	public static double AverageHeight( this Rectangle bounds ) => Average(bounds.Top, bounds.Bottom);
	public static double Average( params double[] values ) => values.Sum() / values.Length;
// then the methods to set the targets
private void NearestPointToolOnChange( object sender, NearestPointEventArgs e )
	try
		ViewModel.CurrentPointIndex = e.Point;
		// ... always are valid values at this point.
		ViewModel.SelectedItemDescription = $"<b>  {newDate}: {result}</b>{Utils.NewLine}  {SourceItem?.Description}: {result}";
	catch ( IndexOutOfRangeException )
		ViewModel.CurrentPointIndex = -1;
		ViewModel.SelectedItemDescription = string.Empty;
	catch ( Exception ex )
		Api.Debug.HandleException(ex);
	finally { AnnotationTool.Active = false; }
private void Chart1_BeforeDrawSeries( object sender, Graphics3D g )
	// DataLine is a Steema.TeeChart.Styles.Line
	double pointPosX = DataLine.CalcXPos(ViewModel.CurrentPointIndex);
	double pointPosY = DataLine.CalcYPos(ViewModel.CurrentPointIndex);
	SetPoints(pointPosX, pointPosY);
private void SetPoints( in double x, in double y )
	// AnnotationTool is a Steema.TeeChart.Tools.Annotation
	AnnotationTool.ConfigureAnnotations(ViewModel.FloatingAnnotations, ViewModel.SelectedItemDescription);
	if ( !AnnotationTool.Active ) { return; }
	Chart1.Title.Visible = ViewModel.FloatingAnnotations;
	if ( !ViewModel.FloatingAnnotations )
		TargetPoint = new Point(x, y - GraphViewModel.ANNOTATION_OFFSET);
		SourcePoint = new Point(AnnotationTool.Left, AnnotationTool.Bounds.Bottom);
		return;
	bool leftBound = x <= Chart1.ChartBounds.AverageWidth();
	bool topBound = y <= DataLine.LocalAveragePos(out double minVerticalValueHeight, out double maxVerticalValueHeight, true);
	double targetY = topBound
						 ? y + GraphViewModel.ANNOTATION_OFFSET
						 : y - GraphViewModel.ANNOTATION_OFFSET;
	TargetPoint = new Point(x, targetY);
	AnnotationTool.Left = Chart1.ChartBounds.AverageWidth();
	AnnotationTool.Top = Chart1.ChartBounds.AverageHeight();
	SourcePoint = new Point(AnnotationTool.Left, AnnotationTool.Top);
	// SourcePoint = IsPhone
	// 				  ? AnnotationTool.GetFloatingSourcePoint(Chart1, ViewModel.AnnotationHeightOffset, minVerticalValueHeight, maxVerticalValueHeight, leftBound, topBound)
	// 				  : AnnotationTool.GetTackingSourcePoint(Chart1, ViewModel.AnnotationHeightOffset, x, y, leftBound, topBound);
private void TChart1_Annotations_AfterDraw( object sender, Graphics3D g )
	if ( ViewModel.CurrentPointIndex < 0 || !AnnotationTool.Active ) return;
	g.Brush.Color = Color.LightSkyBlue;
	if ( Device.RuntimePlatform == Device.Android )
		g.Pen.Width = 2;
		g.Arrow(true, SourcePoint, TargetPoint, 15, 15, 0);
		g.Pen.Width = 1;
		g.Arrow(true, SourcePoint, TargetPoint, 10, 10, 0);
TLC
Post by TLC » Wed Mar 24, 2021 3:28 pm
I got it to render, albeit incorrectly, by subclassing it and invoking the draw call to it. The DrawText method is NOT being called otherwise, for whatever reason.
Edit: AutoSize was being changed for some reason, somewhere. The sizing is ok.
This is a workaround:
	public class AnnotationTool : Annotation
		public AnnotationTool( Chart chart, string text ) : this(chart) => Text = text;
		public AnnotationTool( Chart chart ) : base(chart)
			Active = true;
			Position = AnnotationPositions.Custom;
			TextAlign = TextAlignment.Start;
			AutoSize = true;
			AllowEdit = false;
		public Rectangle GetBounds()
			 // forces a refresh.
			AutoSize = true;
			return Bounds;
		public void Draw( Graphics3D g ) { DrawText(g); }
	// In the graphing page, attach to the AfterDraw event
		AnnotationTool.Draw(g);
And this is the result:
Re: Annotations do not render. Steema.TeeChart.NET.Xamarin.Forms v4.2021.2.25
Post by Pep » Thu Mar 25, 2021 9:22 am
ok great.
Looking at your code, as you have created your custom annotation class , I do not see incorrectly to way that draw method has to be called.
Let me look more carefully, but it looks good to me.
TLC
Post by TLC » Thu Mar 25, 2021 3:18 pm
ok great.
This is a workaround until it is fixed. NOT THE FIX. It should render without having to do that.
https://github.com/Jakar510/DebugSteemaTeeChart
(un)comment Line 203 of GraphPage to see the results.
Post by Pep » Mon Mar 29, 2021 9:45 am
sure, I've added it on our bug/wish list so it can be reviewed for further releases.
