OnClickSeries is not triggered for 3D charts
Re: OnClickSeries is not triggered for 3D charts
Post by Yeray » Thu Jan 19, 2023 2:52 pm
With following delphi code, I'm importing your tee file and adding an OnClickSeries event to the created TDBChart.
var DBChart1: TDBChart;
  Caption:=TeeMsg_Version;
  DBChart1:=TDBChart.Create(Self);
  LoadChartFromFile(DBChart1, 'F:\Downloads\teeFile.tee');
  DBChart1.Parent:=Self;
  DBChart1.OnClickSeries:=ChartOnClickSeries;
procedure TForm1.ChartOnClickSeries(Sender:TCustomChart; Series:TChartSeries; ValueIndex:Integer;
                                    Button:TMouseButton; Shift: TShiftState; X, Y: Integer);
  ShowMessage('OnClickSeries event fired!')
initialization
RegisterTeeStandardSeries;
And it seems to work fine for me here:
I'll give a try at the same in C++Builder.
Post by Yeray » Thu Jan 19, 2023 5:49 pm
Find attached the same project translated to C++Builder.
OnClickSeriesFMXBCB.zip
(10.21 KiB) Downloaded 3411 times
I can't reproduce the problem with it, so I can't say what's wrong in your project yet.
However, you could try if it works for you so we can see if we are missing anything else.
PCSdeZ
Post by PCSdeZ » Fri Jan 20, 2023 2:32 am
Thank you for your patience.
The project you sent me is loading the 2D chart which is what I'm using in my app, but the 3D chart is where it fails.
I'm really sorry because I sent you the teeFile.tee generated by the 2D version and of course it works. Now I'm sending you the teeFile.tee for the 3D graph. I tried the C++Builder project you kindly sent me and it fails here.
Best regards,
Patricio Cerda
teeFile.rar
(1.06 KiB) Downloaded 3278 times
Post by Yeray » Fri Jan 20, 2023 10:19 am
I can reproduce the problem and simplifying it to the minimum, you just need two TBarSeries. The TAreaSeries doesn't look necessary:
var Chart1: TChart;
  Chart1:=TChart.Create(Self);
  with Chart1 do
    Parent:=Self;
    Align:=alClient;
    AddSeries(TBarSeries).FillSampleValues(2);
    OnClickSeries:=Chart1ClickSeries;
procedure TForm1.Chart1ClickSeries(Sender: TCustomChart; Series: TChartSeries;
  ValueIndex: Integer; Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
  ShowMessage('OnClickSeries event fired!');
I've added it to the public tracker: #2584
PCSdeZ
Post by PCSdeZ » Fri Jan 20, 2023 12:47 pm
Just for the context: the other TBarSeries are there because at runtime, on my application, the user can select other datasets ('USD' and/or 'CLP' money exchange, and 'Realizados' o 'Pendientes' items). And the TAreaSeries are also activated or not by the user to show the composed amount between all items on the chart.
So, I activate or deactivate the series depending on the user selection.
Best regards,
Patricio Cerda
Post by Yeray » Mon Jan 23, 2023 5:50 pm
I've just fixed #2584 for the next maintenance release.
PCSdeZ
Post by PCSdeZ » Mon Jan 23, 2023 10:10 pm
Excellent, thanks Yeray!
