Zooming of Annotation tool
Re: Zooming of Annotation tool
Post by Sandra » Thu Aug 05, 2010 9:03 am
Hello Avijit,
Also commented out the ChartControl.Draw().
As i told you, ColorBand tool is not at getting drawn at all.
Ok, I could reproduce it now. If you don't want use ChartControl.Draw() you can customize your values axis using SetMinMax() property as do to next code:
  public void DrawTrend()
      FastLine _FastLIne = new FastLine();
      _FastLIne.FillSampleValues(100);
      Axis _Axis = new Axis();
      ChartControl.Axes.Custom.Add(_Axis);
      _Axis.StartEndPositionUnits = PositionUnits.Percent;
      _Axis.StartPosition = 0;
      _Axis.EndPosition = 100;
      //_Axis.MaximumOffset = 25;
      //_Axis.MinimumOffset = 25;
      _FastLIne.CustomVertAxis = _Axis;
      ChartControl.Series.Add(_FastLIne);
     _Axis.SetMinMax(_FastLIne.MinYValue(), _FastLIne.MaxYValue());
    // ChartControl.Draw();
     ColorBand _ColorBand = new ColorBand(ChartControl.Chart);
     _ColorBand.Axis = _Axis;
     _ColorBand.Color = Color.Yellow;
     _ColorBand.Transparency = 75;
     _ColorBand.Brush.Color = Color.Yellow;
     _ColorBand.Start = _Axis.Minimum;
     _ColorBand.End = _Axis.Maximum;
     ChartControl.Tools.Add(_ColorBand);
Could you please, tell us if previous code is a good solution for you?
Moreover, you can say us if when you utilizes ChartController.Draw() your application works as you want?
I hope will helps.
Avijit
Post by Avijit » Thu Aug 05, 2010 9:17 am
Tell me one thing -
For example say my FastLine series is of 1000 points and all are NaN.
Or say my fastLine series is of 1000 points and all are 0 or someother value. (no change in the value)
In that case, your login will hold good??
regards,
Avijit
Post by Sandra » Thu Aug 05, 2010 12:39 pm
Hello Avijit,
I think that I haven't understood well your problem. Please see next images I made using your code:
Image1: using SetMinMax() property and FillSampleValues=1000:
Image2: using SetMinMax() property, FillSampleValues=1000, and MaximumOffset = 25; MinimumOffset = 25:
Could you please tell us, if in previous images appear your problem with ColorBandTool?
Avijit
Post by Avijit » Thu Aug 05, 2010 1:09 pm
can you do one thing?
Instead of doing FillSampleValues(1000) please create a fastline series with 1000 NaN data.
Then try to call SetMinMax()
Let me know how is it behaving?
Avijit
Post by Sandra » Fri Aug 06, 2010 9:09 am
Hello Avijit,
Ok, I have checked that your request and I have next gotten images:
Image1: Using 1000 NaN and SetMinMax()
Image2: Using 1000 NaN and tChar1.Draw()
It is obviously that in the image1 SetMinMax() doesn't return correctly MaxYvalue, so MinYValue=0, this is correct, but MaxYValue =1E-50, this is incorrect when should be 0, as in image2 using tChart1.Draw(). Could you confirm us if it is your problem when you are using SetMInMax() axes property?
Avijit
Post by Avijit » Fri Aug 06, 2010 10:49 am
Hello Sandra,
My problem is -
1. I cant use SetMinMax because i will not be able to calculate the MaxYValue for all NaN data.
2. If i am not able to calculate the MaxYValue then the ColorBand values are 0.0 and 0.0
Conclution:
I cant use SetMinMax as it is not calculating the MaxYValue correctly.
But its returning ZERO for TChart.Draw is also not correct.
If you see, the Custom axis pixel position (after TChart.Draw pixel positions are calcualted properly) is different and i have associated the ColorBand with the Custom Axis still ColorBand is not drawn.
If Axis is there, Color Band also should be there irrespective of any Series associated with the Custom axis or not. (There may not be any Series associated with the Custom Axis but Custom Axis is there).
Hope i am able to make you understand the problem.
-Avijit
Post by Sandra » Mon Aug 09, 2010 1:12 pm
Hello Avijit,
Please, you could try using YValues.Maximum instead of calling MaxYValue() function in your code as next code:
        //_FastLIne.FillSampleValues(100);
        for (int i = 0; i < 1000; i++)
            _FastLIne.SetNull(i);
        Axis _Axis = new Axis(ChartControl.Chart);
       _Axis.SetMinMax(_FastLIne.YValues.Minimum, _FastLIne.YValues.Maximum);
        _Axis.Automatic = false;
        _ColorBand.Start = _FastLIne.YValues.Minimum;
        _ColorBand.End = _FastLIne.YValues.Maximum;
Could you tell us, if previous code solves your problem?
I hope will helps.
Avijit
Post by Avijit » Mon Aug 09, 2010 2:08 pm
Hello Sandra,
I tried that and the result is same.
What i am saying you is -
My FastLine contails 10 data points. Values are as below -
DataPoint 1 - NAN
DataPoint 2 - NAN
DataPoint 3 - NAN
DataPoint 4 - NAN
DataPoint 5 - NAN
DataPoint 6 - NAN
DataPoint 7 - NAN
DataPoint 8 - NAN
DataPoint 9 - NAN
DataPoint 10 - NAN
Now can you tell me what will be the value of
_FastLine.YValues.Minimum and _FastLine.YValues.Maximum ??
Avijit
Post by Yeray » Wed Aug 11, 2010 2:58 pm
Hi Avijit,
While double.NaN values have to be treated for the developer, it's the same talking about NaN values than Null points, of course assuming that you don't want them to be drawn.
TeeChart calculates internally the Minimum and Maximum visible values of the series assigned to an axis to set the axis Minimum and Maximum. If there is no point visible, both Minimum and Maximum are 0 (both for the series and the axis).
On the other hand, having the axis Minimum = Maximum, makes the series to be drawn in a line, similar to doing:
            tChart1.Axes.Left.StartPosition = 49;
            tChart1.Axes.Left.EndPosition = 51;
So you should prevent it, for example like follows:
            Steema.TeeChart.Styles.FastLine fast1 = new Steema.TeeChart.Styles.FastLine(tChart1.Chart);
            for (int i = 0; i < 25; i++)
                fast1.Add(double.NaN);
            for (int i = 0; i < fast1.Count; i++)
                if (double.IsNaN(fast1.YValues[i])) fast1.SetNull(i);
            fast1.TreatNulls = Steema.TeeChart.Styles.TreatNullsStyle.DoNotPaint;
            if (tChart1.Axes.Left.Minimum == tChart1.Axes.Left.Maximum)
                tChart1.Axes.Left.Automatic = false;
                tChart1.Axes.Left.Minimum = tChart1.Axes.Left.Minimum - 1;
                tChart1.Axes.Left.Maximum = tChart1.Axes.Left.Maximum + 1;
            Steema.TeeChart.Tools.ColorBand colorband1 = new Steema.TeeChart.Tools.ColorBand(tChart1.Chart);
            colorband1.Axis = tChart1.Axes.Left;
            colorband1.Color = Color.Yellow;
            colorband1.Start = tChart1.Axes.Left.Minimum;
            colorband1.End = tChart1.Axes.Left.Maximum;
