Graph Sizing
Re: Graph Sizing
Post by Yeray » Tue Dec 29, 2009 3:27 pm
Hi David,
In the help it is shown the signature that corresponds to the VCL version, where the wrapped ActiveX version comes from:
procedure ChartRect(Left, Top, Right, Bottom: Integer);
Note that in the same help file page, in the example bellow that signature, it is shown how the method should be used, without brackets (with brackets VB6 expects to obtain a result after the method call).
DJ200
Re: Graph Sizing
Post by DJ200 » Tue Dec 29, 2009 4:27 pm
Hello Yeray
Thank you for that explanation. Yes indeed, lower down the page it does show the usage as you describe.
Still not sure why when used with Active Reports the .Align does not show in the properties.
Best wishes
David
Re: Graph Sizing
Post by Yeray » Fri Jan 08, 2010 11:52 am
Hi David,
We've found that the Align property (and probably others too) could appear or not depending on the form base from where it comes. Anyway you could also use left, top, width and height properties.
DJ200
Re: Graph Sizing
Post by DJ200 » Fri Jan 08, 2010 11:59 am
Thanks Yeray
Yes, I use other methods for the odd property that is not available, so it is not really a big deal. There are other properties that sometimes go missing, but I can't think of one just off-hand
Thank you
I hope that you and the Steema team have a very prosperous New Year!
Best regards
David
