Proposed patches for TCHartSeries.Datasource property
h.hasenack
Post by h.hasenack » Fri Jul 24, 2009 11:49 am
The Datasource property clashes with the Datasourceslist property. The datasourceslist is stored using the defineproperties method, and only when Datasources.COunt>1.
The problem is that the datasource property is always stored, causing an overwrite :shock: of the earlier loaded datasources list when the chart series setup is loaded later on.
Therefore the datasource property should be defined as
property DataSource:TComponent read GetDataSource write SetDataSource stored StoreDatasource;
and private function StoreDatasource should be implemented as follows:
function TChartSeries.StoreDatasource:boolean;
  Result:=DataSources.Count=1;
Also something should happen to the TChartSeries.Notification method which causes the datasources list to runs out of sync :x when series are destroyed. Only the Datasource property is checked in the original code, and the datasources list is forgotten :roll: .
procedure TChartSeries.Notification( AComponent: TComponent;
                                     Operation: TOperation);
  inherited;
  if Operation=opRemove then
{$ifdef HH_PATCH_TC_DATASOURCE}
{$endif}
     if AComponent=FTeeFunction then
        FTeeFunction:=nil
      // Update Datasources list
      if assigned(Datasources) and (Datasources.IndexOf(AComponent)>=0) then
        DataSources.Remove(AComponent);
{$else}
      { if "AComponent" is the same as series datasource,
        then set datasource to nil }
     if AComponent=DataSource then
        InternalRemoveDataSource(AComponent);  // 7.0
{$endif}
{$endif}
Finally there is another bug in the datasources handling. When there are multiple datasources and the first one is empty, the depending series are not or wrongly displayed. For this I patched the TCHartSeries.GetDatasource method so it will primarily return the first datasource containing data points. And falls back to the original, returning Datasources[0] or nil.
Function TChartSeries.GetDataSource:TComponent;
VAR i:integer;
  Result:=nil;
  if Assigned(FDataSources) and (FDataSources.Count>0) then
    for i:=0 to FDataSources.Count-1 do
      if TChartSeries(FDataSources[i]).Count>0 then
        Result:=TChartSeries(FDataSources[i]);
        break; // found a series with data
    if not assigned(Result) then
      result:=FDataSources[0];
Regards - Hans
Re: Proposed patches for TCHartSeries.Datasource property
Post by Yeray » Mon Jul 27, 2009 3:13 pm
Hi Hans,
If I understand well the following code should reproduce the issues you are explaining. But I can't reproduce it with v8.
var Bar1, Bar2, Bar3: TBarSeries;
    Line1: TLineSeries;
var i: Integer;
  Chart1.View3D := false;
  Bar1 := TBarSeries.Create(self);
  Bar2 := TBarSeries.Create(self);
  Bar3 := TBarSeries.Create(self);
  Chart1.AddSeries(Bar1);
  Chart1.AddSeries(Bar2);
  Chart1.AddSeries(Bar3);
  Line1 := TLineSeries.Create(self);
  Chart1.AddSeries(Line1);
  Line1.FunctionType := TAverageTeeFunction.Create(self);
  for I := 0 to 4 do
    Bar1.Add(100);
    Bar2.Add(200);
    Bar3.Add(300);
  Line1.DataSources.Add(Bar1);
  Line1.DataSources.Add(Bar2);
  Line1.DataSources.Add(Bar3);
  Line1.CheckDataSource;
  Line1.DataSource := Bar3;
procedure TForm1.Button2Click(Sender: TObject);
  Bar1.Clear;
After loading the chart, the average function shows the average of the three functions (DataSourcesList) that is 200.
After pressing button 1, nothing happens. If I understood well, assigning a DataSource should take preference from the DataSourcesList (where there are still the three bars).
After pressing button 2, the new DatasourcesList (now with 2 series) seems to be checked fine.
h.hasenack
Post by h.hasenack » Tue Jul 28, 2009 7:46 am
Hi Yeray
It seems hard to find out again what exactly went wrong with the datasources. But anyway, the 'stored' predicate is still useful for the datasource property.
Check this piece of dfm,
    object BarSum: TLineSeries
      Marks.Arrow.Visible = True
      Marks.Callout.Brush.Color = clBlack
      Marks.Callout.Arrow.Visible = True
      Marks.Visible = False
      DataSource = BarSeries1
      Pointer.InflateMargins = True
      Pointer.Style = psRectangle
      Pointer.Visible = False
      XValues.Name = 'X'
      XValues.Order = loAscending
      YValues.Name = 'Y'
      YValues.Order = loNone
      DataSources = (
        'BarSeries1'
        'BarSeries2'
        'BarSeries3')
      object TeeFunction1: TAddTeeFunction
      end
    end
The line DataSource = BarSeries1 should be omitted as it conflicts with the Datasources = (...) setting. Luckily, de datasources property is stored AFTER the datasource property so no-one will notice this. But one should never rely on the order in which properties are stored.
I'm still working on reproducing the error for which the other datasources patch was required.
regards - Hans
h.hasenack
Post by h.hasenack » Tue Jul 28, 2009 8:06 am
Hi Yeray
:idea: I have managed to reproduce the trouble:
1) Run my testapp, attached to this post.
2) Click btTestSTack to add some data th the chart
3) click btTestDatasource 1, this frees BarSeries1
Hey!? My BarSum series is empty! :shock: This happens because the datasources list is cleared when 'by coincidence' the first datasource series is destroyed. This should not happen since there are 2 more datasources.
8) PS there also is a test incorporated for exporting the form to a file Formresource1.txt to demonstrate the storage of the datasource and datasources properties. (btTestDatasourceStorage)
Regards - Hans
TestTChart.zip
Demo app demonstrating datasources trouble
(28.91 KiB) Downloaded 359 times
Post by Yeray » Tue Jul 28, 2009 8:41 am
Hi Hans,
I used your application to see how DataSource and DataSourcesList seem to be correctly synchronized:
2) Click btTestSTack to add some data the the chart
2.1) Click btTestDataSourceStorage to generate the corresponding txt with all the properties:
  DataSources = (
        'BarSeries1'
        'BarSeries2'
        'BarSeries3')
3) click btTestDatasource1, this frees BarSeries1
3.1) Click again btTestDataSourceStorage to generate the txt with the actual properties. As you'll see, Bar1 has been removed from the DataSourcesList and DataSource has been changed also for BarSeries2:
  DataSource = BarSeries2
  DataSources = (
        'BarSeries2'
        'BarSeries3')
Then, I've added a BarSum.CheckDataSource call at btTestDatasource1 after freeing BarSeries1 and now the line doesn't disappear.
Anyway, having a DataSourcesList, probably there is no need to have a DataSource property. So I've added it to the wish list to be revised for future releases.
On the other hand, I'm still not reproducing the problem of having a series without data in the DataSourcesList.
h.hasenack
Post by h.hasenack » Tue Jul 28, 2009 8:46 am
Yeray,
The patch provided for TChartSeries.GetDatasource seems to be uncessesary for Tee8 as the new CalculateFunctionMany routine no longer relies on only the GetDatasource returned series to determine the # points to process. That's a lot better fix than mine... :roll:
<snip>
      // Find datasource with bigger number of points... 5.02
      with ParentSeries do
      for t:=0 to DataSources.Count-1 do
      if Assigned(DataSources[t]) and
         (TChartSeries(DataSources[t]).Count>Source.Count) then
        Source:=TChartSeries(DataSources[t]);
        XList:=Source.NotMandatoryValueList;
<snip>
So the only fixes left for the datasources are:
1) The fix for the "stored" predicate of the Datasource property
2) The fix for the Notification, which I have currently boiled down to
  inherited;
{$ifdef HH_PATCH_TC_DS_NOTIFY}
{$endif}
        FTeeFunction:=nil
     if (FDatasources<>nil) and (FDatasources.Indexof(aComponent)>=0) then
{$else}
{$endif}
{$endif}
Regards - Hans
Post by Yeray » Tue Jul 28, 2009 10:20 am
Hi Hans,
You patches look good. I've added them to the wish list to be revised asap (TV52014317).
Post by Narcís » Mon Mar 29, 2010 2:12 pm
Hi Hans,
Notice that I have implemented your enhancement suggestions to TeeChart v8 and TeeChart 2010.
h.hasenack
Post by h.hasenack » Mon Mar 29, 2010 3:04 pm
Thx
Hans
