When displaying crossTab stacked bars, width of the stacked bar is not uniform. The green series (in this case) is wider.
Is this a known problem?
I use 8.06 Pro.
Best regards,
S. Wagner
stacked bar of uneven width
- bar with uneven width.jpg (4.43 KiB) Viewed 9059 times
Re: stacked bar of uneven width
Hi S. Wagner,
I've tried to reproduce it with the demo at All features\Welcome !\Database Charts\DB Crosstab source but couldn't. Could you please send us a simple example project we can run as-is to reproduce the problem here? Thanks in advance.
where would I send it to?
Brgds.
Steffen
Brgds.
Steffen
Hi Steffen,
You can attach your files to your forums posts at the "Upload attachment" tab below the message text window.
Hola muchachos,
here comes the sample project (compiled with D6 and Advantage Database client)
Brgds.
Steffen
Brgds.
Steffen
- sample.zip
- (498.29 KiB) Downloaded 551 times
Hola Steffen!
Could you please try adding the following?
Series1.BarWidthPercent:=70;
"70" does the trick!
It seems to be Teechart's magic number as it does not work with any other (I tried 65, 75 and 80).
If Editor (Series-Format-Size-Bar width) is set to "70", then additional line
Series2.BarWidthPercent := 70;
is not even necesarry.
To me, this looks like a bug, isn't it?
Thanks anyway,
Steffen
Thanks anyway,
Steffen
Hi Steffen,
I've added this to the wish list to be revised in future releases (TV52014584).
