TMyPointSeries - Only with vertical lines?
Heinz
Post by Heinz » Mon Dec 28, 2009 5:16 pm
MyPoint series draws a vertical and horizontal line from the axes to each series point.
Is it possible to draw this series only with the vertical lines shown(= hide the horizontal lines)?
Thanks and best regards
Re: TMyPointSeries - Only with vertical lines?
Post by Yeray » Tue Dec 29, 2009 3:46 pm
Hi Henz,
No, it's not possible right now. I'll add this to the wish list to be implemented in future releases (TV52014610).
In the meanwhile you could do something as following or modify the method procedure TMyPointSeries.DrawValue(ValueIndex:Integer) if you are a source code customer.
var points1: TPointSeries;
  Chart1.View3D:=false;
  points1:=Chart1.AddSeries(TPointSeries.Create(self)) as TPointSeries;
  points1.FillSampleValues(10);
  points1.OnGetPointerStyle:=OnGetSeriesPointerStyle;
Function TForm1.OnGetSeriesPointerStyle(Sender:TChartSeries; ValueIndex:Integer):TSeriesPointerStyle;
  if ((Sender.XValue[ValueIndex] >= Chart1.Axes.Bottom.Minimum) and (Sender.XValue[ValueIndex] <= Chart1.Axes.Bottom.Maximum)) then
    Chart1.Canvas.Pen.Color:=clRed;
    Chart1.Canvas.Line(Sender.CalcXPos(ValueIndex),Sender.CalcYPos(ValueIndex),Sender.CalcXPos(ValueIndex),Chart1.Axes.Bottom.PosAxis);
  result:=psDiamond;
