Can I set the scale for axis.
For eg:- If I say as
With .Axis.Left
.SetMinMax -105.22 , 130
Then the dll itself sets the scale as 20. Which makes my bubble size small as in the attached image. I want to set the Y axis to have a scale of 50. so that the values in y-axis will be some thing like -100,-50,0,50,100,150. How can I do this.
Thanks in advance
CS.
- SampleForSettingScales.JPG (33.66 KiB) Viewed 4322 times
Re: Can I set the scale for axis
Hi CS,
The following code seems to work fine for me here. Could you please modify it so that we can reproduce your problem here?
Private Sub Form_Load()
TChart1.Aspect.View3D = False
TChart1.AddSeries scBubble
Dim i As Integer
For i = 0 To 29
TChart1.Series(0).asBubble.AddBubble (i * 5) + 50, 0, Rnd * 10, "", clTeeColor
Next i
With TChart1.Axis.Left
.SetMinMax -105.22, 130
.Increment = 50
End With
End Sub
