not all labels are displayed on bottom axis
SvenE
Post by SvenE » Thu Jan 07, 2010 10:47 am
For some years now we create a specific chart see below chart and data. Since we are using the teechart . net V3 for visual studio 2008 we are see that not all labels are displayed on the bottom axis. Is there some changed functionality in version 3?
The graphserie has the following settings
Type= GraphSerie.SerieStyles.StyleLine
Color = System.Drawing.Color.Black
LineStyle = Drawing2D.DashStyle.Solid
We add data using
AddDataPoint(New GraphData(<label>,<value>))
image of chart with complete bottom axis
image of chart with incomplete bottom axis
Re: not all labels are displayed on bottom axis
Post by Narcís » Thu Jan 07, 2010 3:04 pm
Hi SvenE,
TeeChart sources are constantly being modified and we are constantly trying to enhance them and fix as many bugs as possible. However, it can also happen that some functionality has been broken. Anyway, I would expect functionality being the same in this field. Could you please check if latest TeeChart for .NET v3 update build available solves the problem at your end and if it doesn't attach a simple example project we can run "as-is" to reproduce the problem here and let us know which which TeeChart version it worked as expected?
SvenE
Post by SvenE » Thu Jan 07, 2010 3:20 pm
I downloaded the laters version today and the problem still exists.
The version TeeChartNET12004.16592.exe did not have this problem. I'll check if I can create a simple test application to demonstrate the issue. Can I upload a RAR file tot this forum?
Post by Narcís » Thu Jan 07, 2010 3:24 pm
Hi SvenE,
Thanks for your feedback. That's TeeChart for .NET v1 Build 1.1.2004.16592 from June 2005.
Excellent, thanks!
Yes, I think so.
SvenE
Post by SvenE » Fri Jan 08, 2010 8:08 am
Hi I want to upload a rar with the sample visual studio solution, but your upload routine has a max file size of 512KiB. the upload is 1.138. Is there an other way to send you this sample?
Post by Narcís » Fri Jan 08, 2010 9:00 am
Hi SvenE,
Please try posting it at our upload page:
http://www.steema.net/upload
SvenE
Post by SvenE » Fri Jan 08, 2010 9:08 am
I uploaded the sample project using the upload page,
regards,
Marc Evers
Post by Narcís » Fri Jan 08, 2010 3:33 pm
Hi Marc,
Thanks for the example project. I could reproduce the issue here. I checked it works fine in TeeChart for .NET v1 and v2 but fails in v3 and 2009. I've added the defect to the list to be fixed with ticket number TF02014629.
In the meantime, a workaround is using custom labels, for example:
		Dim myXMLfile As String = "tchart.xml"
		Dim ds As New DataSet()
		Dim fsReadXml As New System.IO.FileStream(myXMLfile, System.IO.FileMode.Open)
		Try
			ds.ReadXml(fsReadXml)
		Catch ex As Exception
			MessageBox.Show(ex.ToString())
		Finally
			fsReadXml.Close()
		End Try
		With TChart1
			.Dock = DockStyle.Fill
			Dim s As TeeChart.Styles.Line = New TeeChart.Styles.Line(.Chart)
			s.LinePen.Style = Drawing2D.DashStyle.Solid
			s.LinePen.Width = 1
			s.LinePen.EndCap = Drawing2D.LineCap.Round
			s.Color = Color.Black
			.Legend.CustomPosition = False
			.Legend.ResizeChart = True
			.Axes.Right.Grid.Visible = False
			s.Title = "sample chart"
			For Each row As DataRow In ds.Tables(2).Rows
				s.Add(CDbl(row(1).ToString()), row(0).ToString)
			Next
			.Axes.Bottom.Labels.Items.Clear()
			For i As Integer = 1 To s.Count - 1
				If s.Labels(i) <> "" Then
					.Axes.Bottom.Labels.Items.Add(s.XValues(i), s.Labels(i))
				End If
			Next
		End With
Hope this helps!
SNSSEC
Post by SNSSEC » Mon Mar 01, 2010 12:56 pm
We applied the workaround. We now wait for a release with a proper fix.
Post by Narcís » Tue Mar 02, 2010 8:56 am
Hi SNSSEC,
This has been fixed for last TeeChart for .NET 2009 maintenance release:
http://www.teechart.net/support/viewtop ... =4&t=10807
