Clipping of LineSeries
Heinz
Post by Heinz » Mon Jan 25, 2010 11:20 am
having LineSeries the datapoints with Y-values lower than LeftAxis.Minimum are not shown:
But switching to 3D-view the datapoints with Y-values lower than LeftAxis.Minimum are visible:
Is there a possibility to make these points unvisible in 3D-view?
Best regards
Re: Clipping of LineSeries
Post by Narcís » Mon Jan 25, 2010 12:02 pm
Hi Heinz,
I'm afraid not. This is a known issue in the wish-list (TV52013260) which we will try to enhance for future releases. It's not an easy one though. It will probably involve important series painting redesign.
Post by Yeray » Mon Jan 25, 2010 12:15 pm
Hi Heinz,
As an update, a workaround could be using null points to hide the ones out of the axis range. Something like following:
var i: Integer;
  Series1.TreatNulls:=tnDontPaint;
  Series1.IgnoreNulls:=false;
  for i := 0 to Series1.Count-1 do
    if Series1.YValue[i] < Chart1.Axes.Left.Minimum then Series1.SetNull(i)
    else Series1.SetNull(i,false);
Heinz
Post by Heinz » Mon Jan 25, 2010 12:33 pm
Hi Narcis & Yeray,
many thanks for your answers.
In the meantime I also found a workaround by setting the valuecolor-property for these points to clNone.
Best regards
Heinz
Post by Yeray » Mon Jan 25, 2010 12:55 pm
Hi Heinz,
That's what null points do internally ;)
