line series with different style
schafma
Post by schafma » Mon Feb 01, 2010 10:31 am
is it possible to have different line styles (e.g. dash and solid) on the very same series?
What I'm trying to do is to code additional infomation (data is trustworthy or not) using the line style.
Different colors would be no solutions since there are several lines in one chart.
Hopefully you have an idea,
Marcus
Re: line series with different style
Post by Sandra » Mon Feb 01, 2010 12:13 pm
Hello schafma,
Is not possible have different line styles for one series. I recommend that do something as next code:
 private Steema.TeeChart.Styles.Line line, line1;
            line = new Steema.TeeChart.Styles.Line(tChart1.Chart);
            line1 = new Steema.TeeChart.Styles.Line(tChart1.Chart);
            line.FillSampleValues(10);
            line1.FillSampleValues(5);
            for (int i = 0; i <= (line.Count)/2; i++)
                line1[i].X = line[i].X;
                line1[i].Y = line[i].Y;
            line.LinePen.Style = System.Drawing.Drawing2D.DashStyle.Dash;
            line.LinePen.Width = 3;
            line1.LinePen.Style = System.Drawing.Drawing2D.DashStyle.Solid;
            line1.LinePen.Width = 3;
            line1.Color = line.Color;
Please, check next code works if you want.
I hope will helps.
schafma
Post by schafma » Wed Feb 10, 2010 1:15 pm
Dear Sandra,
thank you for the idea. I'm not quite sure if this solution is flexible enough for my needs but I'll give it a try.
I had also the idea to use the colors arrays of the line series to assign different alpha values (opacities) to the according line segments.
Once again thank you for your help.
Maybe this feature (different line styles per line segment) will be implemented in a futur release.
Marcus
Post by Yeray » Fri Feb 19, 2010 4:28 pm
Hi Marcus,
Here it is another possibility, maybe more flexible (you could have an array of segments in the line to be discontinuous and check it in the condition into the GetPointerStyle event)
        Steema.TeeChart.Styles.Line line;
            line.Pointer.Visible = true;
            line.GetPointerStyle += new Steema.TeeChart.Styles.CustomPoint.GetPointerStyleEventHandler(line_GetPointerStyle);
        void line_GetPointerStyle(Steema.TeeChart.Styles.CustomPoint series, Steema.TeeChart.Styles.GetPointerStyleEventArgs e)
            if ((e.ValueIndex == 3) || (e.ValueIndex == 6)) line.LinePen.Style = System.Drawing.Drawing2D.DashStyle.Dash;
            else line.LinePen.Style = System.Drawing.Drawing2D.DashStyle.Solid;
            e.Style = Steema.TeeChart.Styles.PointerStyles.Nothing;
