TChart 2010 VCL - Bug in TColorLineTool
ScottSlater
Post by ScottSlater » Wed May 19, 2010 2:17 am
I think I have run into a bug with the TColorLineTool when zooming and unzooming a chart. Here is some sample code that you can use to repro the bug. This was done using the new TChart 2010 VCL with Delphi 2007. Machine is running Windows Vista Ultimate, 32-bit, 4GB ram.
procedure TForm6.FormCreate(Sender: TObject);
var i,j: Integer;
    tmpColorLine: TColorLineTool;
  Chart1.AddSeries(TBarSeries.Create(Self));
  for i:=0 to 50 do
    Chart1[0].Add(10*i);
  tmpColorLine:=TColorLineTool.Create(Self);
  tmpColorLine.Axis:=Chart1.Axes.Left;
  tmpColorLine.Value:=100;
  tmpColorLine.Pen.Color:=clRed;
  tmpColorLine.Pen.Width:=2;
  Chart1.Tools.Add(tmpColorLine);
  tmpColorLine.Value:=200;
  tmpColorLine.Pen.Color:=clGreen;
  tmpColorLine.Value:=300;
  tmpColorLine.Pen.Color:=clBlue;
  tmpColorLine.Value:=400;
  tmpColorLine.Pen.Color:=clBlack;
The sample will create a simple bar chart with 4 TColorLines with different colors. Zoom in and out several times and you will notice that some of the lines will start to disappear after zooming out even though they should be visible. If you look closer you will see that what is actually happening is the line's value is being changed and in fact the line is visible. It's just merged with another line because it's value is now the same as the other line. If you zoom in and out enough, eventually you will end up with a single line (actually all 4 lines having the same value).
Unless I'm mistaken, I don't think this should be happening. Please advise.
Scott
Re: TChart 2010 VCL - Bug in TColorLineTool
Post by Yeray » Wed May 19, 2010 11:46 am
Hi Scott,
You could try with:
tmpColorLine.NoLimitDrag:=true;
ScottSlater
Post by ScottSlater » Wed May 19, 2010 5:02 pm
Initial testing seems to show that adding "NoLimitDrag := True" prevents the problem from happening.
However, I still think that the line values should not be changing just because the chart was zoomed regardless of the NoLimitDrag setting. Can you confirm this is an issue?
Scott
Post by Yeray » Thu May 20, 2010 1:59 pm
Hi Scott,
Well, it is a known issue recently discussed in the NET forums as you'll see here.
I've added to the ticket number [TF02014836] that VCL behaves in the same way so the enhancement would be implemented in both versions.
ScottSlater
Post by ScottSlater » Thu May 20, 2010 7:09 pm
Cool. Thanks!
Scott
