Start angle of donut series.
gerhardsachs
Post by gerhardsachs » Sat Aug 21, 2010 10:24 am
In a donut series with 12 equally sized segments, I have to ensure that segment 1..12 is exactly located at clock positions 1..12.
It is easy to rotate the series to achieve correct positioning.
But I have to use different rotation angles on the official TeeChart 2010 release and the latest sources that were sent as bugfix.
The chart would be totally confusing to the customer, if I could not guarantee the correct position.
Currently everything is ok, but what about future releases, do I have to adjust the rotation angle ?
I would prefer to have a well defined and constant start position for the first segment.
Gerhard Sachs
Re: Start angle of donut series.
Post by Yeray » Mon Aug 23, 2010 12:33 pm
Hi Gerhard,
I'm not sure to reproduce it. I'm running the following code in the latest published version and in the actual sources and I'm getting the same result.
uses TeeDonut;
var Series1: TDonutSeries;
  Series1:=Chart1.AddSeries(TDonutSeries) as TDonutSeries;
  Series1.Add(20);
  Series1.Add(10);
  Series1.Add(20);
  Series1.Add(25);
  Series1.Add(25);
  Series1.Shadow.Visible:=false;
  Series1.RotationAngle:=90;
Could you please try to modify the code above so we can see the difference here? Or, please, arrange a simple example project where we can see it.
