Draw Legend
fredff13
Draw Legend
Post by fredff13 » Mon Oct 11, 2010 3:35 pm
After I downloaded update from October 5 for version 2010 I found a bug: the legend drawn after chart drawn event (see below) not fully covers old one. Old legend's first item above newly drawn legend items (I think that all other covered).
procedure TfrmMain.chartAfterDraw(Sender: TObject);
(Sender As TChart).Legend.DrawLegend;
Re: Draw Legend
Post by Yeray » Wed Oct 13, 2010 10:20 am
Hi fredff13,
I'm not sure to understand what are you exactly trying to do, and neither what is the exact difference in behaviour between versions you see.
fredff13
Re: Draw Legend
Post by fredff13 » Wed Oct 13, 2010 6:05 pm
Hi, I set Legend.Visible to False to avoid drawing at position which not matching run-time one. It's still a bug as it has not been observed in previous version (legend was drawing on top of each other, so fully covered "visible" legend). See attached screen shots.
Thanks, Fred
Drawing Legend with updated version
Re: Draw Legend
Post by Narcís » Fri Oct 15, 2010 8:22 am
Hi fredff13,
As Yeray already asked, it would be very helpful for us to be able to provide an accurate answer if you could provide a simple example project we can run "as-is" to reproduce the problem here.
fredff13
Re: Draw Legend
Post by fredff13 » Thu Oct 28, 2010 8:38 pm
I have attached simple project as you requested
DrawLegend.zip
Issue with drawing legend after chart was drawn (overlapping)
(9.86 KiB) Downloaded 455 times
Re: Draw Legend
Post by Narcís » Tue Nov 02, 2010 9:07 am
Hi fredff13,
In which TeeChart version do you think this worked fine? Also, what are you trying to achieve with this? We may be able to provide an alternative solution.
fredff13
Re: Draw Legend
Post by fredff13 » Tue Nov 02, 2010 3:10 pm
Hello, I just pointed to that version before the latest update has not such effect. Legend design-time position was the same as was drawn by DrawLegend function.
Thanks, Fred
Re: Draw Legend
Post by Narcís » Wed Nov 03, 2010 3:49 pm
Hi Fred,
Thanks for the information. I found that v2010.00.00407 worked as you expected while this behaviour changed in v2010.01.11004. I have added the issue to the defect list (TV52015261) to be investigated.
Re: Draw Legend
Post by Narcís » Thu Dec 30, 2010 11:02 am
Hi Fred,
I just wanted to inform you that I have fixed this bug for the next TeeChart 2010 VCL maintenance release. If you are a source code customer you can implement the fix at your end doing a little change at Chart.pas. At TCustomChartLegend.DrawLegend method add tmpRect variable of TRect type and change this code:
      with tmpChart.ChartRect do
        ShapeBounds.Top:=Top+tmp+Round(1.0*FTopLeftPos*(Bottom-Top-tmp)*0.01);
for this:
      if {$IFNDEF CLR}TCustomChartAccess{$ENDIF}(ParentChart).CustomChartRect then
        tmpRect:=tmpChart.ChartRect
        tmpRect:=tmpChart.ChartBounds;
      with tmpRect do
