Plotting Several Charts
lilo
Post by lilo » Tue Oct 12, 2010 2:29 pm
Is it possible to plot several charts on one tchart control without overprinting of the axes?
I have plotted 12 Ternary charts, each containing a seperate set of data. However, the axes and labels overprint each other, resulting in blurry text.
See jpeg...
Re: Plotting Several Charts
Post by Sandra » Wed Oct 13, 2010 9:32 am
Hello lilo,
Well, seems it is a known issue (TV52015067) recently discussed in the VCL forums as you'll see here
I've added to the ticket number [TF02015203]. So the enhancement would be implemented in next versions of TeeChart.Net.
lilo
Post by lilo » Fri Oct 15, 2010 2:00 pm
We also like to have a font property for the vertex labels and a fix for the right vertex 0 label - does not update font size properly when font size is changed for labels.
Post by Sandra » Mon Oct 18, 2010 9:40 am
Hello lilo,
I have added your suggestion as a feature request with number [TF02015224] to be considered for inclusion in future versions of TeeChart.Net
You are right. I have added your request in bug list with number [TF02015226]. We will try to fix it for next maintenance releases of TeeChart.Net.
