BackImage Stream and clear
mivchart
Post by mivchart » Thu Feb 24, 2011 8:33 am
Hello
D2007 and TeeTree VCL 8.04
I load BackImage from Stream, it's Ok that good result with under methode
function LoadBackImageFromStream:Boolean;
Var i:integer;
jpg: TJPEGImage;
Stream1:TMemoryStream;
try
Stream1:=TMemoryStream.Create;
jpg:=TJPEGImage.Create;
try
Stream1:=GetStreamImageFromSever; //Load Stream from my server by Webservice > it's Ok
if Stream1.size>=0 then
jpg.LoadFromStream(Stream1);
Tree1.BackImage.Assign(jpg);
finally
FreeAndNil(jpg);
FreeAndNil(Stream1);
except
//managment error
Q1) do hou have other solution for direct load image by stream, without TJPEGImage and without file disk?
Q2) How do take for clear Image if my stream is empty or bad ?
Q3) do you have best practice and géneral méthode for image (jpeg,bmp,Gif etc) without file disk ?
Re: BackImage Stream and clear
Post by Narcís » Thu Feb 24, 2011 11:29 am
Hi mivchart,
I think those are Delphi generic issues. I'll give my 2 cents. though.
You could use TBitmap as in the code snippet below.
var Bitmap: TBitmap;
    Stream: TMemoryStream;
  Bitmap:=Bitmap.Create;
  Stream:=TMemoryStream.Create;
  //Load your image to the stream here.
  if Assigned(Stream) then
    Stream.Position:=0;
    Bitmap.LoadFromStream(Stream);
Use Assigned as in the code snippet above.
I don't know if this is best practice but I'd try doing something as in the code example I posted.
mivchart
Post by mivchart » Thu Feb 24, 2011 1:47 pm
OK,
But if my Stream used for several type (Jpeg, Gif, Bmp, etc), for each i need déclare spécial grapic type ??
Post by Yeray » Fri Feb 25, 2011 3:17 pm
Hi mivchart,
You could try with TOleGraphic as in the example here.
Also, if you are source code customer, feel free to look into TeeChart sources to see how the different types are treated.
