Michael Heinrich
Post
by Michael Heinrich » Wed Aug 10, 2011 9:29 am
I am trying to figure out how to calculate the center of a pie in a chart that holds multiple pie series. I would like to place an annotation at that position with that tells the user what pie he's looking at.
What I have started is the following code. I am not sure when the CircleXCenter actually changes as they are all (0,0) for all my series in the chart. I've looked at the drawing of the pie in the sourcecode but it uses the canvas for it's coordinates. How do I position an annotation at the pie's center?
lTool := TAnnotationTool( SomeChart.Tools.Add( TAnnotationTool ) );
lTool.Text := SomePieSeries.Title;
lTool.Left := SomePieSeries.CircleXCenter;
lTool.Top := SomePieSeries.CircleYCenter;
Post
by Yeray » Wed Aug 10, 2011 12:23 pm
Hello Michael,
Maybe you are using CircleXCenter and CircleYCenter values before the Pies are drawn so that values are still incorrect. Try adding a Draw call to force a chart repaint.
The following example seems to work fine for me here:
private
{ Private declarations }
procedure Pie1BeforeDrawValues(Sender: TObject);
procedure Pie2BeforeDrawValues(Sender: TObject);
procedure Pie3BeforeDrawValues(Sender: TObject);
procedure Pie4BeforeDrawValues(Sender: TObject);
uses Series, TeeTools;
var margin: Integer;
var i: Integer;
margin:=10;
Chart1.Legend.Visible:=false;
for i:=0 to 3 do
Chart1.AddSeries(TPieSeries).FillSampleValues();
with Chart1.Tools.Add(TAnnotationTool) as TAnnotationTool do
Text:='Pie nº ' + IntToStr(i);
Chart1[0].BeforeDrawValues:=Pie1BeforeDrawValues;
Chart1[1].BeforeDrawValues:=Pie2BeforeDrawValues;
Chart1[2].BeforeDrawValues:=Pie3BeforeDrawValues;
Chart1[3].BeforeDrawValues:=Pie4BeforeDrawValues;
Chart1.Draw;
procedure TForm1.Pie1BeforeDrawValues(Sender: TObject);
Chart1.ChartRect:=Rect(margin, margin, Chart1.Width div 2, Chart1.Height div 2);
procedure TForm1.Pie2BeforeDrawValues(Sender: TObject);
Chart1.ChartRect:=Rect(Chart1.Width div 2, margin, Chart1.Width - margin, Chart1.Height div 2);
procedure TForm1.Pie3BeforeDrawValues(Sender: TObject);
Chart1.ChartRect:=Rect(margin, Chart1.Height div 2, Chart1.Width div 2, Chart1.Height - margin);
procedure TForm1.Pie4BeforeDrawValues(Sender: TObject);
Chart1.ChartRect:=Rect(Chart1.Width div 2, Chart1.Height div 2, Chart1.Width - margin, Chart1.Height - margin);
var i: Integer;
with (Chart1.Tools[i] as TAnnotationTool) do
Left:=(Chart1[i] as TPieSeries).CircleXCenter - (Chart1.Canvas.TextWidth(Text) div 2);
Top:=(Chart1[i] as TPieSeries).CircleYCenter - (Chart1.Canvas.TextHeight(Text) div 2);
Michael Heinrich
Post
by Michael Heinrich » Wed Aug 10, 2011 12:48 pm
Hello Yeray,
Adding an explicit draw before positioning the textlabels did the trick. I then added your afterdraw event mechanism to place the labels which fixed the redrawing after resizing the program window.
Michael.
Post
by Yeray » Wed Aug 10, 2011 1:05 pm
Hello Michael,
I'm glad to hear it!
