Pie Charts
MikeTheLad
Pie Charts
Post by MikeTheLad » Thu Oct 13, 2011 12:32 pm
Some queries on the attached Pie Charrt:-
On the numbers around the graph, require no box and the font to bigger
How do I force the order, We need the white to be top and then clockwise with the others
Re: Pie Charts
Post by Sandra » Fri Oct 14, 2011 9:29 am
Hello MiketheLad,
I suggest you define the position of your values when you add it in the series, as do in next example of code:
        Steema.TeeChart.Styles.Pie Series1;
            Series1 = new Steema.TeeChart.Styles.Pie(tChart1.Chart);
            Series1.Add(74);
            Series1.Add(6);
            Series1.Add(5);
            Series1.Add(8);
            Series1.Add(4);
            Series1.Marks.Style = Steema.TeeChart.Styles.MarksStyles.Percent;
Can you tell us if previous code helps you to solve your problem?
MikeTheLad
Re: Pie Charts
Post by MikeTheLad » Fri Oct 14, 2011 1:32 pm
I have treid changing the order, but seem unable to get the white to be at the top, also what about the box and font size of the labels next to the pie
Steema.TeeChart.TChart tChart2 = new Steema.TeeChart.TChart();
Steema.TeeChart.Styles.Pie pie = new Steema.TeeChart.Styles.Pie(tChart2.Chart);
tChart2.Legend.Visible = false;
tChart2.Header.Text = "";
tChart2.Chart.Panel.Color = System.Drawing.Color.White;
tChart2.Chart.Panel.Visible = false;
tChart2.Chart.Walls.Visible = false;
tChart2.Chart.Panel.Bevel.Outer = Steema.TeeChart.Drawing.BevelStyles.None;
tChart2.Chart.Panel.Bevel.Inner = Steema.TeeChart.Drawing.BevelStyles.None;
tChart2.Aspect.View3D = false;
pie.Add(Convert.ToInt32(ethnicperc1), ethnicperc1 + "%", Color.FromArgb(49, 151, 101));
pie.Add(Convert.ToInt32(ethnicperc3), ethnicperc3 + "%", Color.FromArgb(245, 152, 31));
pie.Add(Convert.ToInt32(ethnicperc4), ethnicperc4 + "%", Color.FromArgb(205, 205, 205));
pie.Add(Convert.ToInt32(ethnicperc5), ethnicperc5 + "%", Color.FromArgb(244, 243, 160));
pie.Add(Convert.ToInt32(ethnicperc6), ethnicperc6 + "%", Color.FromArgb(157, 197, 233));
pie.Add(Convert.ToInt32(ethnicperc2), ethnicperc2 + "%", Color.FromArgb(255, 255, 255));
Re: Pie Charts
Post by Sandra » Mon Oct 17, 2011 9:37 am
Hello MikeTheLad,
Using last version of TeeChart2011 and next code:
           Steema.TeeChart.Styles.Pie pie = new Steema.TeeChart.Styles.Pie(tChart1.Chart);
           tChart1.Header.Text = "";
           pie.Circled = true;
           tChart1.Chart.Panel.Color = System.Drawing.Color.White;
           tChart1.Chart.Panel.Bevel.Outer = Steema.TeeChart.Drawing.BevelStyles.None;
           tChart1.Chart.Panel.Bevel.Inner = Steema.TeeChart.Drawing.BevelStyles.None;
           Random rnd = new Random();
           int ethnicperc1, ethnicperc2, ethnicperc3,ethnicperc4, ethnicperc5, ethnicperc6;
           ethnicperc1 = 74;
           ethnicperc2 = 4;
           ethnicperc3 = 6;
           ethnicperc4 = 2;
           ethnicperc5 = 5;
           ethnicperc6 = 8;
           pie.Add(ethnicperc1, ethnicperc1.ToString() + "%", Color.FromArgb(49, 151, 101));
           pie.Add(ethnicperc3, ethnicperc3.ToString() + "%", Color.FromArgb(245, 152, 31));
           pie.Add(ethnicperc4, ethnicperc4.ToString() + "%", Color.FromArgb(205, 205, 205));
           pie.Add(ethnicperc5, ethnicperc5.ToString() + "%", Color.FromArgb(244, 243, 160));
           pie.Add(ethnicperc6, ethnicperc6.ToString() + "%", Color.FromArgb(157, 197, 233));
           pie.Add(ethnicperc2, ethnicperc2.ToString() + "%", Color.FromArgb(255, 255, 255));
I have gotten next results:
Can you try again run previous code and tell us if you can get a good results? On the other hand, If you doesn't use last version of TeeChartFor.Net, please tell us which version are you using now.
Sorry I forgot answer this question. If you want as the boxs of Marks don't appear and font of Marks is to bigger, you need use next properties of Marks to modify their aspect:
  • - Series.Marks.Pen.Visible = False or True;
    - Series.Marks.Color.Transparency= 100. You have indicate the % of transparency you want to marks. And also you can use Series.Marks.Transparent = true; where you indicate as if you want Mark transparent or not.
    - Series.Marks.Font.Size = 12. To Change the size of font.
I have added some of previous properties in your code:
           //Marks;
           pie.Marks.Transparent = true;
           pie.Marks.Transparency = 100;
           pie.Marks.Pen.Visible = false;
           pie.Marks.Arrow.Visible = false;
           pie.Marks.Font.Size = 12;
And I have gotten next results:
Can you tell us, if previous lines of code works as you expected?
MikeTheLad
Re: Pie Charts
Post by MikeTheLad » Tue Oct 18, 2011 2:26 pm
We need the graph rotating around 90 degress, sample attached of what I am trying to produce
Graph Sample.jpg (26.9 KiB) Viewed 13534 times
Re: Pie Charts
Post by Sandra » Wed Oct 19, 2011 8:16 am
Hello MikeTheLad,
Series have a method that allow rotate the Series. To achieve as you want I recommend rotate your Series an angle of 180º as do in next line of code:
 pie.Rotate(180);
Can you tell us, if previous line works as you expected?
MikeTheLad
Re: Pie Charts
Post by MikeTheLad » Wed Oct 19, 2011 11:52 am
Thanks, that is what I needed
