XE2 Update 4
MHotz
XE2 Update 4
Post by MHotz » Thu Mar 08, 2012 9:35 am
yesterday I installed the latest XE2 Update 4 which was offered automatically by the IDE. After installation I received errors on starting the IDE. After some research I found out that there is a problem with the TeeChart libraries and the XE2 libraries "fmi161.*" and "fmx161.*". The reason is that these libraries no longer exists in XE2. They are now shifted to "fmi162.*" and "fmx162.*". A simple renaming leads to other problems because the libraries interfaces where obviously changed.
Is there allready a solution to that probnlem?
Kind regards
Markus
Re: XE2 Update 4
Post by Narcís » Fri Mar 09, 2012 8:24 am
Hi Markus,
TeeChart sources need to be recompiled for update 4. If you are source code customer you can already do that with the existing source code version. Otherwise you'll have to wait until we publish the binary installers for update 4, which we expect to be soon.
MHotz
Re: XE2 Update 4
Post by MHotz » Fri Mar 09, 2012 11:00 am
Hi Narcis,
thanks! It worked!
Greetings
Markus
Re: XE2 Update 4
Post by Yeray » Wed Mar 28, 2012 8:08 am
We've just published the TeeChart v2012.05 installer supporting XE2 Update 4.
http://www.teechart.net/support/viewtop ... 118#p57118
