Overlapping marks for a line series
Sam F
Post by Sam F » Wed Mar 28, 2012 6:02 am
This is a recurring issue I see. I have attempted to implement the code as referenced at http://www.teechart.net/support/viewtopic.php?t=560.
So, in my test project, I have this code:
__fastcall TFormMain::TFormMain(TComponent* Owner)
  : TForm(Owner)
  Chart1->AddSeries(new TLineSeries(Chart1));
  Chart1->Series[0]->Marks->Visible = true;
  for(int i(0); i < 50; ++i) {
    Chart1->Series[0]->AddXY(i,i);
   Chart1->Draw();
   TRect R1,R2,DummyRect;
   for (int i=0; i<Chart1->Series[0]->Marks->Positions->Count-1; i++)
      for (int j=0; j<Chart1->Series[0]->Marks->Positions->Count-1; j++)
        if (j!=i)
         TSeriesMarkPosition *mp1 = new TSeriesMarkPosition;
         TSeriesMarkPosition *mp2 = new TSeriesMarkPosition;
         mp1=Chart1->Series[0]->Marks->Positions->Position[i];
         mp2=Chart1->Series[0]->Marks->Positions->Position[j];
         R1=mp1->Bounds();
         R2=mp2->Bounds();
         while (IntersectRect(DummyRect, R1, R2))
            mp1->Custom=true;
            mp1->LeftTop.x=mp1->LeftTop.x+2;
            mp1->LeftTop.y=mp1->LeftTop.y+2;
            mp1->ArrowTo.x=mp1->LeftTop.x+2;
            mp1->ArrowTo.y=mp1->LeftTop.y+2;
            R1=mp1->Bounds();
            R2=mp2->Bounds();
         Chart1->Refresh();
However, it seems to make no difference at all. See attached screen capture. The code seems to be getting into the parts editing the Mark position - but it is like the changes are being ignored. Is there a setting I am missing?
Marks problem
Re: Overlapping marks for a line series
Post by Yeray » Wed Mar 28, 2012 3:35 pm
Hi Sam,
I think the code works fine. It's just it's not as smart as this example needs. Note it checks the marks rectangles with two for loops, but once a mark overlap is detected and a mark is moved to fix that overlapping, the next marks are still going to be checked but not the prior.
Here you have an smarter version:
uses Series;
var i: Integer;
  Chart1.AddSeries(TLineSeries);
  Chart1[0].Marks.Visible:=true;
  for i:=0 to 49 do
    Chart1[0].AddXY(i,i);
  function MarkOverlaps(ValueIndex: Integer): Boolean;
  var i: Integer;
      DummyRect: TRect;
    result:=false;
    with Chart1[0].Marks.Positions do
    for i:=0 to Count-1 do
      if (i<>ValueIndex) then
        if IntersectRect(DummyRect, Position[i].Bounds, Position[ValueIndex].Bounds) then
          result:=true;
          break;
var i, j: Integer;
      while MarkOverlaps(i) do
        with Position[i] do
          Custom:=true;
          LeftTop.X:=LeftTop.X+2;
          LeftTop.Y:=LeftTop.Y+2;
          ArrowTo.X:=LeftTop.X+2;
          ArrowTo.Y:=LeftTop.Y+2;
  Chart1.Refresh;
Sam F
Post by Sam F » Wed Mar 28, 2012 11:32 pm
Thank you, that works for me. Much faster having the chart refresh not in the loop as well.
Sam.
Post by Yeray » Fri Mar 30, 2012 7:52 am
Hi Sam,
I'm glad to hear it! :D
