AntiAlias issue
johnnix
AntiAlias issue
Post by johnnix » Fri Mar 30, 2012 6:10 am
I am using TeeChart 2011.03.30407 and I wish someone to inform me if the following bug is fixed in the latest release.
1. Add a TChart into a form
2. Double click and from the editor add a TLineSeries
3. Go to Tools->Other and add the Anti-Alias tool
4. The line should now miss several segments
Thank you all for your time
Re: AntiAlias issue
Post by Yeray » Fri Mar 30, 2012 2:56 pm
Hi Johnnix,
Was this identified in the past? If so, do you know the ticket we assigned to it or the forum thread where we discussed it? I'm not able to find it.
In case it wasn't discussed in the past, I should be missing some relevant step because I can't reproduce it either with v2011.03 nor with the actual v2012.05. So, could you please arrange a simple example project we can run as-is to reproduce the problem here?
johnnix
Re: AntiAlias issue
Post by johnnix » Fri Mar 30, 2012 3:16 pm
Please find a sample app that is not working with my version of TChart.
test.zip
(2.7 KiB) Downloaded 1166 times
Re: AntiAlias issue
Post by Yeray » Tue Apr 03, 2012 8:47 am
Hi Johnnix,
That's what I get with it. I'm not sure to see any "missing segment":
Marco
Re: AntiAlias issue
Post by Marco » Thu Feb 07, 2013 3:17 pm
Hello Yeray,
I am using Teechart 2011.04.41118 for C++ builder and I come across the same issue described in this post.
With the AntiAlias tool on a graph, all non horizontal lines are invisible.
Example with antialias tool :
And without this tool :
Is it a way to correct this problem ? Do I follow the suggestion you gave in this thread http://www.teechart.net/support/viewtop ... =antialias ?
Thanks in advance and best regards.
Marco
Re: AntiAlias issue
Post by Yeray » Fri Feb 08, 2013 9:17 am
Hi Marco,
I've been able to reproduce the problem with the v2011.04 and the code below:
uses Series, TeeAntiAlias, TeeGDIPlus;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
  Chart1.Tools.Add(TAntiAliasTool);
  //Chart1.Canvas:=TGDIPlusCanvas.Create;
  with Chart1.AddSeries(TLineSeries) do
    Pen.Width:=2;
    Add(0);
    Add(100);
    Add(100);
    Add(0);
  Chart1.Axes.Left.SetMinMax(0, 120);
  Chart1.Axes.Bottom.SetMinMax(0.25, 2.5);
However, I can't reproduce it any more with the actual version.
Also, if I use GDIPlus instead of the TAntiAliasTool as you pointed, it seems to work fine in v2011.04.
  //Chart1.Tools.Add(TAntiAliasTool);
Marco
Re: AntiAlias issue
Post by Marco » Fri Feb 08, 2013 3:10 pm
Hello Yeray,
Is this code also usable with C++ builder ? :
I can't use this "TGDIPlusCanvas" type.
I add
#pragma link "TeeGDIPlus"
but TGDIPlusCanvas is unknown.
Re: AntiAlias issue
Post by Yeray » Mon Feb 11, 2013 10:58 am
Hi Marco,
Right, that's Delphi code. It shouldn't be difficult to translate Delphi code but if you have problems with it, please tell us what exact IDE are you using and we'll try to check it in a very same environment than yours.
Marco
Re: AntiAlias issue
Post by Marco » Tue Feb 12, 2013 9:09 am
I would like to use this code with Borland C++ Builder XE, with teechart v2011.04.
Thanks in advance
Re: AntiAlias issue
Post by Yeray » Tue Feb 12, 2013 11:23 am
Hi Marco,
the following code works fine for me here in XE both with TeeChart v2011.04 and the actual v2012.07:
  Chart1->View3D=false;
  Chart1->Legend->Visible=false;
  Chart1->Canvas=new TGDIPlusCanvas();
  TLineSeries *line1 = new TLineSeries(this);
  Chart1->AddSeries(line1);
  line1->Pen->Width=2;
  line1->Add(0);
  line1->Add(100);
  line1->Add(100);
  line1->Add(0);
  Chart1->Axes->Left->SetMinMax(0, 120);
  Chart1->Axes->Bottom->SetMinMax(0.25, 2.5);
I just had to add the TeeGDIPlus header in the .h:
#include "Chart.hpp"
#include "TeEngine.hpp"
#include "TeeProcs.hpp"
#include "Series.hpp"
#include "TeeGDIPlus.hpp"
Marco
Re: AntiAlias issue
Post by Marco » Tue Feb 12, 2013 2:37 pm
It works for me. Thank you !
The final rendering is different that with antialias tool but not so bad.
Re: AntiAlias issue
Post by Yeray » Wed Feb 13, 2013 8:27 am
Hi Chacal,
If you prefer the TAntialiasTool, the only way I see for you is to update to the current version.
