Compilation of VCL under XE3
Lesley
Post by Lesley » Wed Sep 05, 2012 3:39 pm
XE3 is officially avalaible. I've just bought it and tried to compile TeeChartPro for VCL manually, based on the project group without installing TeeChart Standard before with XE3. First in the inc file there are no corresponding definitions for XE3. I extended it. There are a lot of errors during opening the packages. (Class TButtonPen, TButtonColor etc. not defined...)
Did anybody tried it to manually compile and install TeeChart Pro?
Lesley
Re: Compilation of VCL under XE3
Post by Yeray » Thu Sep 06, 2012 7:48 am
Hi Lesley,
We've got to do a significant amount of changes for the Standard version to be shipped into XE3.
That's why I don't think it will be easy to make TeeChart v2012.06 (or any before) compile for XE3.
I'd suggest you to wait until we publish a Pro version (presumably v2012.07) supporting it.
Lesley
Post by Lesley » Thu Sep 06, 2012 8:18 am
Thanks for the fast answer. When do You plan to publish it? I assume, that the VCL part doesn't request such lot modifications. It's were usefull to publish separately for users using VCL, not FM.
Post by Yeray » Thu Sep 06, 2012 8:30 am
Hi Lesley,
I can't tell you a date for it, but we are working to achieve it as soon as possible.
I'm afraid we don't have plans to release any TeeChart VCL-only / not-FMX version at the moment.
Since you are a source code customer, if you don't want to wait, we could prepare an "experimental" source code installer for you.
Post by Narcís » Thu Sep 06, 2012 8:57 am
Hi Lesley,
Just sent an email to the forums profile address with the URL to download the test source code installer Yeray told you.
Lesley
Post by Lesley » Thu Sep 06, 2012 5:03 pm
Thanks for Your assistance! With a little modifications it (the compilation at least) works under XE3 for VCL:
1. These 2 files are to take from the official Juni version: VCLTee.TeeChartPro.pas and VCLTee.Bind.DBLinks.pas. Otherwise I get compilation errors.
2. I used the project file DclTeePro916.dpk. Here were 2 units to expand with the "prefix" VCLTee.
Could You check it?
Best regards and thanks again for the fast help:
Lesley
Jeff Wilhite
Post by Jeff Wilhite » Fri Sep 07, 2012 5:21 pm
So, could I get an experimental source code installer, too? Thanks.
Post by Narcís » Mon Sep 10, 2012 7:38 am
Hi Jeff,
Sure, just sent it.
Elis AS
Post by Elis AS » Wed Sep 12, 2012 7:13 am
Hi!
Could you please send me the experimental installer also?
Post by Narcís » Wed Sep 12, 2012 8:08 am
Yes. I sent it to your forums email address.
Post by Narcís » Wed Sep 12, 2012 2:42 pm
Hi Lesley,
Lesley wrote:Thanks for Your assistance! With a little modifications it (the compilation at least) works under XE3 for VCL:
Thanks for your feedback. We are getting some different errors here with our current sources as well. We had to work on the Standard version shipped with XE3 until the very last minute so the Pro version is still not ready yet.
Post by Narcís » Thu Sep 13, 2012 8:06 am
Hello everyone,
I posted a new test source code installer at the same location. Sources now compile and install correctly in XE3. You may need to disable the "Tee 3D" checkbox.
Nev
Post by Nev » Fri Sep 14, 2012 1:50 am
I have attempted to install 2012 pro src in XE3. No luck. Where have you posted the updated installer?
NH
Post by Yeray » Fri Sep 14, 2012 8:13 am
We are preparing a Pre-Release SourceCode installer. As soon as we'll finish some tests with it, we'll make it available through the download area, only for source code customers.
Post by Narcís » Fri Sep 14, 2012 9:05 am
Hello everyone,
An updated pre-release source code installer has been just posted at the client area for TeeChart Pro source code customers. For more information on the announcement please read this thread.
