Surface3D
tb
Surface3D
Post by tb » Mon Sep 27, 2004 7:37 pm
Does anybody have an example of using the Surface3D of the TDraw3D canvas ? I looked through the demos and googled it, but didn't come up with anything.
-regards,
-Torben
Post by Pep » Tue Sep 28, 2004 7:37 am
Hi Torben,
from sources :
Procedure TTeeCanvas3D.Surface3D( Style:TTeeCanvasSurfaceStyle;                                   SameBrush:Boolean;                                   NumXValues,NumZValues:Integer;                                   CalcPoints:TTeeCanvasCalcPoints );
  { not implemented in GDI mode. (Use TeeOpenGL) }
This method is not implemented for TTeeCanvas3D. Instead, you should use TGLCanvas.Surface3D method ( a bit complicated, but it should work), where :
Style = TTeeCanvasSurfaceStyle=(tcsSolid,tcsWire,tcsDot);
CalcPoints = TTeeCanvasCalcPoints=Function( x,z:Integer; Var P0,P1:TPoint3D;
Var Color0,Color1:TColor):Boolean of object;
tb
Post by tb » Tue Sep 28, 2004 11:55 am
Thanks, I'll have a look :-D
-Torben
