3D chart loses axes
OMP
3D chart loses axes
Post by OMP » Mon Jul 01, 2013 2:41 pm
Dear,
When I add more then 25 lines in my chart which all have only 1 point, my 3D chart looks strange.
This my code:
chartToTest.Aspect.View3D = true;
            for (int i = 0; i < 30; i++)
               Steema.TeeChart.Styles.Line line = new Steema.TeeChart.Styles.Line(chartToTest.Chart);
               line.Pointer.Visible = true;
               line.Add(0, "");
Kind regards
3D chart.PNG (17.77 KiB) Viewed 12637 times
Re: 3D chart loses axes
Post by Sandra » Tue Jul 02, 2013 8:46 am
Hello OMP,
Using your code with latest maintenance release of TeeChartFor.Net ( Build 4.1.2013.05281):
    //  tChart1.Dock = DockStyle.Fill;
        Steema.TeeChart.Styles.Line line = new Steema.TeeChart.Styles.Line(tChart1.Chart);
        line.Add(0, "");
I have gotten next results where your problem doesn't appear.
Could you please tell us which version of TeeChartFor.Net are you using?
OMP
Post by OMP » Tue Jul 02, 2013 10:20 am
I have downloaded the latest version (4.1.2013.5282) and tried it again, but the issue still remains.
Post by Sandra » Tue Jul 02, 2013 12:09 pm
Hello OMP,
Could you please send us your project because we can try to reproduce your problem here, so, using your attached code it doesn't appears for me?
OMP
Post by OMP » Tue Jul 02, 2013 1:07 pm
When I was making the test project, I have noticed that it depends on the size of the window and the number of lines that are used.
In the test project I couldn't reproduce it with 30 lines, but when 50 lines are used, the issue is still there.
I will send the test project to support.
Post by Narcís » Tue Jul 02, 2013 1:23 pm
OMP wrote: I will send the test project to support.
I have edited your email because you posted the Pro Support email address. You can either attach your project here or post it at www.steema.net/upload/
OMP
Post by OMP » Tue Jul 02, 2013 1:56 pm
I've attached the project here now. My apologies for the misunderstanding.
TeeChartTest.zip
(112.47 KiB) Downloaded 786 times
Post by Sandra » Wed Jul 03, 2013 10:18 am
Hello OMP,
We consider it as an enhancement and for this reason we have added it in wish-list with number [TF02016632] to we will consider its inclusion in future maintenance releases of TeechartFor.Net.
