TChart serializable problem
rubby
Post by rubby » Sun Sep 22, 2013 7:28 am
hello,
I see that TChart implements Serializable.
Does it support to save TChart to a file and restore it form the file?
I mean:
if i have an instance
TChart chart = ...;
ObjectOutputStream out = new ObjectOutputStream(new FileOutputStream("chart.dat"));
out.writeObject(chart);
//in another place
ObjectInputStream in = new ObjectInputStream(new FileInputStream("chart.dat"));
TChart chart2 = (TChart)in.readObject();
In this way, i can get the original TChart.
I have tried this.
but it fail.
Do you know how to solve this? thanks.
Re: TChart serializable problem
Post by Narcís » Wed Sep 25, 2013 10:21 am
Hi rubby,
Yes, this is possible using TeeChart native template files (.tej in Java). You'll find more specific information in Tutorial 9. Exporting and Importing Charts. Tutorials can be found at the Docs folder in TeeChart's installation.
rubby
Post by rubby » Wed Oct 02, 2013 8:56 am
But when I try one example of TeeChart for Swing, its path is All features-->Chart styples --> Bar --> Negative Stacked.
In the poped edit dialog, I export its template as xml format,
Some errors happen,
java.lang.NullPointerException
at com.steema.teechart.Aspect.getTextSmooth(Aspect.java:234)
Post by Yeray » Thu Oct 03, 2013 9:30 am
I've just run TeeChart.Features.jar from TeeChart Java Suite with SourceCode v3.2013.0517. I went to the "Negative Stacked" example, opened the editor, navigated to the "Export\Template" tab. Checked the "XML Format" checkbox and pressed "Save" button.
Find attached the xml generated. It looks correct.
Negative and Positive Stacked Bars.zip
(1.44 KiB) Downloaded 2008 times
Do you see any difference between what we are doing?
rubby
Post by rubby » Fri Oct 04, 2013 5:49 am
Hello, Yeray
I did not run it by the TeeChart.Features.jar.
I put the releated example code into netbeans, and run the example from netbeans.
in the output window of nebeans, some errors display.
I think even there is error, the TeeChart.Features.jar has no place to show it, because the error will be catched.
Post by Yeray » Fri Oct 04, 2013 11:14 am
Although I get a correct xml file, I get many errors with the Suite with Sources v3.2013.0517. Find the errors attached (I attached a text file because the string is too long for a post).
However, I don't get any error with the actual sources we have here, so they shouldn't appear in the next version.
errors.zip
(8.46 KiB) Downloaded 1888 times
rubby
Post by rubby » Sun Oct 06, 2013 4:57 am
yes. I encount similar errors too.
Because of them,
when i export TChart and import them then, it fails or some properties are not effected.
rubby
Post by rubby » Sun Oct 06, 2013 5:03 am
Hello Yeray,
Is it possible to give me the new version of source to aviod to exporting errors?
Post by Yeray » Mon Oct 07, 2013 11:57 am
I'll send you a mail with a link to download a private testing version.
rubby
Post by rubby » Thu Jan 16, 2014 2:12 am
Hello, I download the new version TeeChartJava 2013.1219.
But the export import functions still have some problem.
My goal is exporting Tchat to tej or xml, then when i load it, it should be the same to the one i stored.
But this is false.
the following is my code.
import com.steema.teechart.Rectangle;
import com.steema.teechart.TChart;
import com.steema.teechart.axis.Axis;
import com.steema.teechart.drawing.Color;
import com.steema.teechart.editors.ChartEditor;
import com.steema.teechart.styles.Bar;
import com.steema.teechart.styles.HorizBar;
import com.steema.teechart.styles.Series;
import java.awt.BorderLayout;
import java.awt.event.ActionEvent;
import com.steema.teechart.styles.Box;
import java.awt.event.WindowAdapter;
import java.awt.event.WindowEvent;
import java.awt.event.ActionListener;
import java.io.FileNotFoundException;
import java.io.IOException;
import java.util.logging.Level;
import java.util.logging.Logger;
import javax.swing.JButton;
import javax.swing.JFrame;
import javax.swing.JMenu;
import javax.swing.JMenuBar;
import javax.swing.JMenuItem;
import javax.swing.JOptionPane;
import javax.swing.JPanel;
import javax.swing.UIManager;
import javax.swing.UnsupportedLookAndFeelException;
 *  测试TeeChart使用
 * @author tom
public class TestTeeChart {
     * @param args
     *            the command line arguments
        try {
            UIManager.setLookAndFeel(UIManager.getSystemLookAndFeelClassName());
        } catch (Exception ex) {
            Logger.getLogger(TestTeeChart.class.getName()).log(Level.SEVERE, null, ex);
        MenuFrame frame = new MenuFrame();
        frame.initChart();
        frame.setVisible(true);
class MenuFrame extends JFrame {
    public static final Color FEATURES_TREECOLOR = new Color(234, 238, 255);
    public static final String FEATURES_URL = "features/features.xml";
    public static final String NEW_FEATURES_URL = "features/new.xml";
    private TChart tChart = null;
    public MenuFrame() {
        JFrame.setDefaultLookAndFeelDecorated(true);
        this.setTitle("TeeChart for java");
        this.setDefaultCloseOperation(JFrame.DO_NOTHING_ON_CLOSE);
        this.addWindowListener(new WindowAdapter() {
            public void windowClosing(WindowEvent we) {
                System.exit(0);
        this.setLayout(new BorderLayout());
        JMenuBar menuBar = new JMenuBar();
        JMenu opMenu = new JMenu("Operation");
        JMenuItem saveItem = new JMenuItem("save");
        JMenuItem openItem = new JMenuItem("load");
        JMenuItem editItem = new JMenuItem("edit");
        opMenu.add(saveItem);
        opMenu.add(openItem);
        opMenu.add(editItem);
        saveItem.addActionListener(new ActionListener() {
            public void actionPerformed(ActionEvent e) {
                if (tChart != null) {
                    try {
                        tChart.setText("Stored chart");
                        tChart.getSeries(0).setTitle("StoreA");
                        tChart.getSeries(1).setTitle("StoreB");
                        Axis bottom = tChart.getAxes().getBottom();
                        System.out.println(bottom.getLabels().getItems().size());
                        bottom.getLabels().getItems().add((double) 0, "MyXLabel-1");
                        bottom.getLabels().getItems().add((double) 1, "MyXLabel-2");
                        tChart.repaint();
                        JOptionPane.showMessageDialog(null, "Current tchart will be stored");
                        tChart.getExport().getTemplate().toFile("c:\\tt23.tej");
                        tChart.getExport().getTemplate().toXML("c:\\tt23.xml");
                        tChart.getAspect().setView3D(true);
                        tChart.setText("New Chart");
                        tChart.getSeries(0).setTitle("new A");
                        tChart.getSeries(1).setTitle("new B");
                        bottom.getLabels().getItems().clear();
                        bottom.getLabels().getItems().set( 0, "new-1");
                        tChart.repaint();
                    } catch (IOException ex) {
                        Logger.getLogger(MenuFrame.class.getName()).log(Level.SEVERE, null, ex);
        openItem.addActionListener(new ActionListener() {
                    try {
//                        tChart.getImport().getTemplate().fromFile("c:\\tt23.tej"); //load fail
                        tChart.getImport().getTemplate().fromXML("c:\\tt23.xml");
                        tChart.updateUI();
                        tChart.repaint();
        editItem.addActionListener(new ActionListener() {
                    ChartEditor.editChart(tChart.getChart());
        menuBar.add(opMenu);
        setJMenuBar(menuBar);
        pack();
        this.setSize(600, 800);
        setLocationRelativeTo(null);
//        setVisible(true);
    public void initChart() {
        tChart = new TChart();
        tChart.addSeries(new Bar());
        tChart.getSeries(0).add(1, 10);
        tChart.getSeries(0).add(2, 15);
        tChart.getSeries(0).setTitle("A series");
        tChart.getSeries(1).add(1, 20);
        tChart.getSeries(1).add(2, 35);
        tChart.getSeries(1).setTitle("Bseries");
        tChart.setBounds(new Rectangle(0, 0, 500, 500));
        //设置图标的属性
        tChart.getAspect().setView3D(false); // no 3D
        this.add(tChart, BorderLayout.CENTER);
        JButton button = new JButton("Edit");
        button.addActionListener(new ActionListener() {
        this.add(button, BorderLayout.NORTH);
1. tej xml problem
I store the Tchart to c:\\tt23.xml and c:\\tt23.tej. (Stored Chart.png)
But when i load c:\\tt23.xml, the X axix label is not "MyXLabel-2". (xml loaded.png)
when i load c:\\tt23.tej, the "Stored chart" does not showed. Nothing changed (tej loaded.png)
What's more, there are some errors in the IDE outp0ut. My IDE is netbeans.
2. i want to know how to calculate the correct position of label item. so "MyXLabel-1" and "MyXLabel-2" can be presented correctly.
"bottom.getLabels().getItems().add((double) 0, "MyXLabel-1");" // in fact i want to add "MyXLabel-1" as the first label
xml loaded.png (16.29 KiB) Viewed 38587 times
tej loaded.png (19.63 KiB) Viewed 38592 times
Stored Chart.png (16.22 KiB) Viewed 38591 times
rubby
Post by rubby » Thu Jan 16, 2014 2:19 am
After the program runs. please click operation--> save.
Then click operation--> load
The output errors are:
at com.steema.teechart.drawing.Gradient.getCustomTargetRectangle(Gradient.java:448)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at sun.reflect.misc.Trampoline.invoke(MethodUtil.java:37)
at sun.reflect.GeneratedMethodAccessor2.invoke(Unknown Source)
at sun.reflect.misc.MethodUtil.invoke(MethodUtil.java:244)
at java.beans.Statement.invokeInternal(Statement.java:239)
at java.beans.Statement.access$000(Statement.java:39)
at java.beans.Statement$2.run(Statement.java:140)
at java.security.AccessController.doPrivileged(Native Method)
at java.beans.Statement.invoke(Statement.java:137)
at java.beans.Expression.getValue(Expression.java:98)
at java.beans.DefaultPersistenceDelegate.doProperty(DefaultPersistenceDelegate.java:210)
at java.beans.DefaultPersistenceDelegate.initBean(DefaultPersistenceDelegate.java:247)
at java.beans.DefaultPersistenceDelegate.initialize(DefaultPersistenceDelegate.java:395)
at java.beans.PersistenceDelegate.writeObject(PersistenceDelegate.java:100)
at java.beans.Encoder.writeObject(Encoder.java:54)
at java.beans.XMLEncoder.writeObject(XMLEncoder.java:257)
at java.beans.Encoder.writeExpression(Encoder.java:279)
at java.beans.XMLEncoder.writeExpression(XMLEncoder.java:372)
at java.beans.DefaultPersistenceDelegate.doProperty(DefaultPersistenceDelegate.java:212)
at java.beans.PersistenceDelegate.writeObject(PersistenceDelegate.java:97)
at java.beans.Encoder.writeObject1(Encoder.java:206)
at java.beans.Encoder.cloneStatement(Encoder.java:219)
at java.beans.Encoder.writeStatement(Encoder.java:250)
at java.beans.XMLEncoder.writeStatement(XMLEncoder.java:331)
at java.beans.XMLEncoder.writeObject(XMLEncoder.java:260)
at com.steema.teechart.exports.TemplateExport.toXML(TemplateExport.java:168)
at com.steema.teechart.exports.TemplateExport.toXML(TemplateExport.java:109)
at com.steema.teechart.exports.TemplateExport.toXML(TemplateExport.java:98)
at com.teechart.test.MenuFrame$2.actionPerformed(TestTeeChart.java:117)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.AbstractButton.doClick(AbstractButton.java:357)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:1223)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:1264)
at java.awt.Component.processMouseEvent(Component.java:6267)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6032)
at java.awt.Container.processEvent(Container.java:2041)
at java.awt.Component.dispatchEventImpl(Component.java:4630)
at java.awt.Container.dispatchEventImpl(Container.java:2099)
at java.awt.Component.dispatchEvent(Component.java:4460)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4577)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
at java.awt.Container.dispatchEventImpl(Container.java:2085)
at java.awt.Window.dispatchEventImpl(Window.java:2478)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Post by Yeray » Fri Jan 17, 2014 3:32 pm
Thanks for the info. We'll investigate it and reply you here asap.
Post by Yeray » Tue Jan 21, 2014 12:03 pm
Hello rubby,
We've made some tests with the Swing features demo shipped with the installation, concretely with the example at "All features\Welcome!\Exporting\Native binary format".
- With NetBeans, create a "new project from existing sources" and use the features demo project at "Examples\Swing\Features\src\features"
- Open the project properties and make it use the TeeChart.Swing.jar at the Libraries menu.
- Change TemplateDemo.java with the following:
    protected void initChart() {
        super.initChart();
        copyChart = new TChart();
        chart1.addSeries(new Bar());
        chart1.getSeries(0).add(1, 10);
        chart1.getSeries(0).add(2, 15);
        chart1.getSeries(0).setTitle("A series");
        chart1.getSeries(1).add(1, 20);
        chart1.getSeries(1).add(2, 35);
        chart1.getSeries(1).setTitle("Bseries");
        chart1.setText("Stored chart");
        chart1.getSeries(0).setTitle("StoreA");
        chart1.getSeries(1).setTitle("StoreB");
        Axis bottom = chart1.getAxes().getBottom();
It seems to work without problems:
It also shows the same good result if I change the code for the "run button" to use a tej file instead of a memory stream:
    public void actionPerformed(ActionEvent ae) {
        Object source = ae.getSource();
        if (source == editButton) {
            ChartEditor.editChart(chart1.getChart());
        } else if (source == editButton2) {
            ChartEditor.editChart(copyChart.getChart());
        } else if (source == runButton) {
            try {
                chart1.getExport().getTemplate().toFile("C:\\tmp\\serialiseTest.tej");
            } catch (FileNotFoundException ex) {
                Logger.getLogger(TemplateDemo.class.getName()).log(Level.SEVERE, null, ex);
            try {
                copyChart.setChart(copyChart.getImport().getTemplate().fromFile("C:\\tmp\\serialiseTest.tej"));
            } catch (ClassNotFoundException ex) {
            copyChart.refreshControl();
So, try adding the copyChart.refreshControl(); call after importing the tej file.
Also please check your project is referencing the correct jar and not a TeeChart.Swing.jar from a previous version.
rubby
Post by rubby » Tue Jan 21, 2014 3:37 pm
Hello, Yeray,
thank you sincerely for your reply.
1. I am sure that my project is referencing the correct jar, TeeChart.Swing.jar from directory TeeChartJavaSrc_3.2013.1219.
So it is the latest version. I have checked this several times.
2. your test is using the example at "All features\Welcome!\Exporting\Native binary format".
But "MyXLabel-1" is still not showed corrected. only "MyXLabel-2" is showed.
3. Yes, I believe there is no error in your test. I also try your test immediately. But one test may be not enough.
Could you please spend some time on my test example and tell me what's wrong with it?
I think my test example uses the correct export and import methods provided with TeeChart.
After my example started, I click operation--> save.
Then click operation--> load, the saved tchart will not presented correctly.
I am confused with this problem for several months.
thanks again for your time and reply.
Post by Marc » Wed Jan 22, 2014 11:30 am
In your sample code you are adding data at X 1 and 2:
..and you are adding the labels at 0 and 1. At 0 there is no data and so no label appears. There are other ways to paint labels at all locations if required.
Alternatively there are different approaches to adding labels.
For example you could add them with the data:
com.steema.teechart.styles.Bar bar = new com.steema.teechart.styles.Bar(chart1.getChart());
bar.clear();
bar.add(0, 123, "ABC", Color.RED);
bar.add(1, 456, "DEF", Color.BLUE);
bar.add(2, 321, "GHI", Color.GREEN);
bar.add(3, 321, "JKL", Color.YELLOW);
will give the following output:
TeeChart Java template export 1
or you can override the default labels as you have done (here applying the index to two of the points that have been added):
bar.clear();
chart1.getAxes().getBottom().getLabels().getItems().add((double) 0, "MyXLabel-1");
chart1.getAxes().getBottom().getLabels().getItems().add((double) 1, "MyXLabel-2");
That will give the following output:
TeeChart Java template export 2
I hope that may be of help.
