App is crashing when CircularGauge property DisplayTotalAngle is set to specific value.
TeeChartNETMonoTouch_v4_13_04_05
Circular gauge DisplayTotalAngle Xamarin.ios
Re: Circular gauge DisplayTotalAngle Xamarin.ios
Hello Thomas,
I'm not able to reproduce the problem here ? Could you please post the code you're using in order to get the problem here ?
Do you set the DisplayTotalAngle after the Series have been added to the Chart ?
Pep Jorge
http://support.steema.com
I found out that app crashes when DisplayTotalAngle is set and FaceBrush.Visible = false.
ex:
circularGauge.DisplayTotalAngle = 180;
circularGauge.TotalAngle = 180;
circularGauge.FaceBrush.Visible = false;
As workaround i set FaceBrush backround as white, and disable gradient and it works.
But chart looks pretty strange. How to remove 3d effect (show on screenshot)?. I need simple 2d gauge.
ex:
- Screen Shot 2013-10-18 at 2.29.21 PM.png (35.14 KiB) Viewed 8527 times
Hello Thomas,
yes, you're correct, I've been able to reproduce the problem here.
It has been already fixed for inclusion into the next maintenance release.
Thanks !
Thanks !
Pep Jorge
