Labels and Titles way too large when printing
kant
Post by kant » Wed Oct 16, 2013 9:30 am
I habe an MS Access application with a integrated linechart both on a preview form and a printed report.
All label and title sizes are defined at runtime and share the same code. Graph title is a label on Access report.
Up to TeeChart 2012 everything works fine. With the latest 2013 version the preview form looks as before
but the printed report has grossly oversized labels and titles.Reverting to 2012 resolves the problem.
Also, PDF created with 2012 is 78 KB, with 2013 3802 KB and the printer usually returns a memory error.
Strangely, the file information on the 2013.ocx shows some rather dated version information.
Thanks for your help,
Andreas
Screen 2013
Print 2013
Print 2012
Re: Labels and Titles way too large when printing
Post by Yeray » Fri Oct 18, 2013 11:01 am
I'm trying to reproduce the problem here but I can't. Can you please arrange a simple example project we can run as-is to reproduce the problem here?
kant
Post by kant » Fri Oct 25, 2013 6:44 pm
Yeray,
My project is pretty large and retrieves it's data from MS SQL Server.
I could not yet get around to make a sample Database.
Will get back on this in 2 weeks.
Best regards,
Andreas
Post by Yeray » Wed Oct 30, 2013 9:03 am
Hi Andreas,
If the data isn't relevant, you could try just with FillSampleValues or a simple routine adding some points.
kant
Post by kant » Fri Nov 22, 2013 10:03 am
It took me a while to produce the Test database.
It is an Access 2003-DB and has 1 form and 1 report.
Just open them.
The form is always fine unless you want to print it.
Andreas
Test_TeeChart1.zip
(114.45 KiB) Downloaded 1804 times
Post by Narcís » Fri Nov 22, 2013 11:53 am
Hi Andreas,
Thanks for the example. I can not run it due to missing Codejock.Controls.v15.0.2.ocx. However, the issue most likely is the same as discussed here: http://bugs.teechart.net/show_bug.cgi?id=69. This will be included in the following TeeChart Pro ActiveX maintenance release.
kant
Post by kant » Mon Nov 25, 2013 10:25 am
Hi Narcís
The description fits my problem.
Also I have built a modified example
with the Codejock reference removed.
Andreas
Test_TeeChart2.zip
(130.42 KiB) Downloaded 1766 times
Post by Narcís » Mon Nov 25, 2013 11:13 am
Hi Andreas,
Thanks for your feedback. I could reproduce the issue with your file now. We exepct the fix being included for the next maintenance release. If you are interested, we could send you a test .ocx.
kant
Post by kant » Mon Nov 25, 2013 2:46 pm
Hi Narcís
I'd gladly test the revised ocx on my full project.
Best regards,
Andreas
Post by Narcís » Tue Nov 26, 2013 1:00 pm
Hi Andreas,
Ok, just sent you a test .ocx to your forums profile email address.
kant
Post by kant » Wed Nov 27, 2013 2:22 pm
Hi Narcis
Thanks for your test OCX.
We are not quite there yet - see the enclosed JPEG's.
Please note that that title and footer text
are directly on the MS Access form/report,
not on the TeeChart control.
Best wishes,
Andreas
Post by Narcís » Thu Nov 28, 2013 12:37 pm
Hi Andreas,
Could you please attach the new example project?
kant
Post by kant » Fri Nov 29, 2013 10:36 am
Hi Narcís
I used my production tool to produce the images.
So here's my Test.mdb modified to work with your Test.ocx.
The symptoms are the same.
Best wishes,
Andreas
Test_TeeChart3.rar
(94.86 KiB) Downloaded 1872 times
Post by Narcís » Fri Nov 29, 2013 4:14 pm
Hi Andreas,
We are investigating the issue here. In the meantime, a workaround is disabling GDI+ in your chart:
     TChart1.Aspect.GDIPlus.Active = False
kant
Post by kant » Wed Feb 26, 2014 12:55 pm
Hi Narcis
Are there any news on this?
Disabling GDI+ is a momentary workaround but printouts are not really satisfactory ...
I could also live with an older fully functional 2013 Version for the moment.
Best wishes,
Andreas
