LinearGage numeric value
Hi! I'm using Xamarin.Android teechart.
I want to place numeric representation of value in LinearGauge in center of bar (like on screenshot)
I draw that value in AfterDraw event.
But when i calculate size from the top left corner of chart - and adjust it to specific device - on another device it is in wrong place (i use proper px to dp transformation). I need calculate text position from border top left corner (not whole chart corner)
1) how to get border top left corner coordinates (red arrow on screenshot)? i can't find appropriate properties.
2) how to change border color?
Thanks in advance
Thanks in advance
- gauge.png (28.5 KiB) Viewed 18191 times
Re: LinearGage numeric value
Hi Thomas,
1. You can do this:
2. See gauge.Frame.InnerBand.Color property in the example.
1. You can do this:
public class MyLinearGauge : LinearGauge
public MyLinearGauge(Chart chart) : base(chart) { }
public Rectangle AxisRectangle
get
int height, width, x, y;
if (Horizontal)
height = Ticks.VertSize;
width = Utils.Round(INewRectangle.Width * 0.8);
x = (INewRectangle.X + (INewRectangle.Width / 2)) - (width / 2);
y = INewRectangle.Y + ((INewRectangle.Height - height) / 2);
height = Utils.Round(INewRectangle.Height * 0.8);
width = Ticks.VertSize;
return new Rectangle(x, y, width, height);
[Activity(Label = "TeeChart for MonoDroid Demo", MainLauncher = true)]
public class Activity1 : Activity
protected override void OnCreate(Bundle bundle)
base.OnCreate(bundle);
InitializeChart();
private Steema.TeeChart.TChart tChart1;
MyLinearGauge gauge;
tChart1 = new Steema.TeeChart.TChart(this);
gauge = new MyLinearGauge(tChart1.Chart);
gauge.FillSampleValues();
tChart1.AfterDraw += tChart1_AfterDraw;
gauge.Frame.InnerBand.Color = Color.Cyan;
SetContentView(tChart1);
Point topleft = gauge.AxisRectangle.Location;
g.Pen.Width = 3;
g.Pen.Color = Color.Pink;
g.Line(topleft, new Point(200, 10));
Thanks. 1-st part works perfect.
Frame color deosn't work. When i make FrameVisible, disable Middle and outer bands It draws one more rectangle outside small thin frame. Seems like frame on first screenshot - is not related to LinearLayout.Frame property.
Hi Thomas,
I get a chart like in the image below. Is that what you get? What's the problem with it?
I'm not sure about which is the problem you describe. Adding this code:Thomas wrote: Frame color deosn't work. When i make FrameVisible, disable Middle and outer bands It draws one more rectangle outside small thin frame. Seems like frame on first screenshot - is not related to LinearLayout.Frame property.
gauge.Frame.Visible = true;
gauge.Frame.MiddleBand.Visible = false;
gauge.Frame.OuterBand.Visible = false;
I have another problem. When i draw line from Point
from your first response everything is OK on all devices. The line draws from corner.
But when I try to draw text with
g.TextOut (topleft.X, topleft.Y, "1234");
text is drawed on different positions on Y axis on different devices. g.TextOut works with the same coordinate system? How to draw text in center of bar?
Hi Thomas,
With a Bar series, this:
Yes.Thomas wrote:g.TextOut works with the same coordinate system?
Continuing with the MyLinearGauge example, you can do this:Thomas wrote:How to draw text in center of bar?
g.Pen.Width = 3;
Point center = new Point(topleft.X + gauge.AxisRectangle.Width / 2, topleft.Y + gauge.AxisRectangle.Height / 2);
g.Font.Color = Color.Red;
g.TextOut(center.X, center.Y, "My custom text");
InitializeChart();
Bar bar1;
Rectangle[] barRect;
bar1 = new Bar(tChart1.Chart);
bar1.FillSampleValues();
barRect = new Rectangle[bar1.Count];
bar1.GetBarStyle += bar1_GetBarStyle;
void bar1_GetBarStyle(CustomBar sender, CustomBar.GetBarStyleEventArgs e)
barRect[e.ValueIndex] = sender.BarBounds;
for (int i = 0; i < bar1.Count; i++)
string text = bar1.YValues[i].ToString();
SizeF textSize = g.MeasureString(g.Font, text);
int X = barRect[i].X + Steema.TeeChart.Utils.Round(barRect[i].Width / 2) - Steema.TeeChart.Utils.Round(textSize.Width / 2);
int Y = barRect[i].Y + Steema.TeeChart.Utils.Round(barRect[i].Height / 2) - Steema.TeeChart.Utils.Round(textSize.Height / 2);
g.TextOut(X, Y, text);
Size of drawing text is strange. Text "100000" has height > widht. height is very big. I
I found solution
It works.
I have last question. On some devices CircularGauge axis labels are far from the border(see screenshot), on other near the border(frame). All ticks sizes are zero. How to set labels near the frame?
I found solution
var topleft = gauge.AxisRectangle.Location;
g.TextOut (topleft.X + gauge.AxisRectangle.Width/2, topleft.Y - (int)textSize.Height + gauge.AxisRectangle.Height - (gauge.AxisRectangle.Height - g.Font.Size) / 2 + 2, value);
- g1.png (14.4 KiB) Viewed 18096 times
Hi Thomas,
Those are decimals, that's because width and height are float numbers. You can check it using this code:Thomas wrote:Size of drawing text is strange. Text "100000" has height > widht. height is very big.
g.Font.Size = 14;
g.Font.Bold = true;
string text = "100000";
int x = Steema.TeeChart.Utils.Round(textSize.Width);
int y = Steema.TeeChart.Utils.Round(textSize.Height);
g.TextOut(x, y, text + ". Position: " + x.ToString() + " - " + y.ToString());
Which kind of devices? Are those low resolution screened devices? Which sort of screens in the table here? Anyway, you can change that with Ticks.VertSize:Thomas wrote:On some devices CircularGauge axis labels are far from the border(see screenshot), on other near the border(frame). All ticks sizes are zero. How to set labels near the frame?
circularGauge1.Ticks.VertSize = 0;
Still cannot change border color (see my 1st post in this topic).
Frame property is other frame, not the frame near hand (see attachment to first post).
Hi Thomas,
Apologies for the misunderstanding. That frame is the axis, hence you can change its pen properties like this:
Is that what you were looking for?
gauge.Axis.AxisPen.Color = Color.Red;
gauge.Axis.AxisPen.Width = 5;
Thanks. It works
