Bar Chart does not Resize Correctly
lilo
Post by lilo » Fri Jan 31, 2014 6:24 pm
If a Bar Chart is resized on a form interactively by dragging the form handle bars and resizing the bar chart on the fly in code, a gap appears on the left of the chart between the y-axis and first sample.
Re: Bar Chart does not Resize Correctly
Post by Christopher » Mon Feb 03, 2014 12:51 pm
Running this code:
      tChart1.Series.Add(typeof(Bar)).FillSampleValues();
and then resizing the chart by resizing the form does not reproduce the problem here. Could you please modify the above code snippet so I can reproduce the problem at my end?
lilo
Post by lilo » Tue Feb 04, 2014 2:13 am
I changed some of my code and it started working correctly...
