TeeChart 2014.10.140220 VCL/FMX release available
Post by Narcís » Mon Feb 24, 2014 11:39 am
Greetings!
Steema Support Central writes to inform you of the availability of the latest TeeChart VCL/FMX release which adds support for RAD Studio XE5 Update 2, which includes C++ Builder iOS support.
TeeChart VCL/FMX customers may download the version at no-charge from the customer download page.
The 2014.10 update includes installers for all development environments supported and adds full support for RAD Studio XE5 Update 2.
The release also contains many new features, improvements and bug fixes. Release notes may be viewed at the version info page.
mknorr
Re: TeeChart 2014.10.140220 VCL/FMX release available
Post by mknorr » Mon Mar 17, 2014 3:15 pm
If there is a problem with the XE5 release perhaps? The download of TeeChart2014RADXE.exe works fine, the download of TeeChart2014RADXE5.exe always leads to a timeout...
Post by Yeray » Mon Mar 17, 2014 3:55 pm
I've just downloaded TeeChart2014RADXE5.exe without problems. Note the installer for XE5 is bigger than the installer for XE (319MB vs 52MB).
I wonder if the connection you've used to download the installers is stable enough.
MarineObjects
Post by MarineObjects » Tue Apr 15, 2014 11:04 am
TeeChart Pro 2014 won't compile/install in Delphi XE6. The TeeChart Source Code Recompilation Tool returns the following message;
TeeChart Pro
Compilation started: 15-4-2014 12:53:05
Win32 v20 Enterprise
Tee920
Embarcadero Delphi for Win32 compiler version 27.0
Copyright (c) 1983,2014 Embarcadero Technologies, Inc.
87324 lines, 0.69 seconds, 960144 bytes code, 4540 bytes data.
TeeUI920
79533 lines, 0.58 seconds, 618912 bytes code, 1368 bytes data.
TeeDB920
8482 lines, 0.25 seconds, 88436 bytes code, 288 bytes data.
TeePro920
206220 lines, 1.11 seconds, 1290028 bytes code, 6412 bytes data.
TeeGL920
16517 lines, 0.25 seconds, 133800 bytes code, 3156 bytes data.
TeeImage920
24882 lines, 0.33 seconds, 319588 bytes code, 11380 bytes data.
TeeWorld920
2679 lines, 0.22 seconds, 19444 bytes code, 280 bytes data.
TeeLanguage920
83440 lines, 0.48 seconds, 3405768 bytes code, 3496 bytes data.
DclTee920
8297 lines, 2.65 seconds, 153112 bytes code, 348 bytes data.
DclTeePro920
5013 lines, 0.61 seconds, 201404 bytes code, 464 bytes data.
DclTeeProStd920
10799 lines, 0.58 seconds, 175964 bytes code, 444 bytes data.
TeeMaker120
86617 lines, 3.76 seconds, 830500 bytes code, 12760 bytes data.
DclTeeMaker120
947 lines, 0.66 seconds, 18808 bytes code, 204 bytes data.
FMXTee920
Cannot recompile Delphi package: FMXTee920.dpk
FMXTee.Chart.pas(903) Error: E2037 Declaration of 'DragOver' differs from previous declaration
FMXTee.Chart.pas(3088) Error: E2008 Incompatible types
FMXTee.Chart3D.pas(515) Fatal: F2063 Could not compile used unit 'FMXTee.Chart.pas'
EXCEPTION:
Compilation aborted.
Post by Yeray » Tue Apr 15, 2014 11:20 am
MarineObjects wrote:TeeChart Pro 2014 won't compile/install in Delphi XE6. The TeeChart Source Code Recompilation Tool returns the following message
I'm afraid we haven't yet published any release supporting this IDE. Please stay tuned.
LibertyTrooper
Post by LibertyTrooper » Thu Apr 24, 2014 6:04 am
What may someone, in the interim, do to allow use in XE6? Is there, perhaps a porting document?
You know how it goes... Tell someone that a compiler upgrade from D7 is going to solve their problems and if you take a week they are talking about returning to D7....
R,
Dave
Post by Narcís » Thu Apr 24, 2014 7:04 am
Hi Dave,
I sent you an URL to download a beta test version for XE6.
sicorspa
Post by sicorspa » Mon May 05, 2014 9:02 am
can I also have the link for the beta?
Many thanks
Post by Narcís » Mon May 05, 2014 9:15 am
It was made available as a regular beta download for all source code customers. You just need to log in to the client download area with your source code license details to get it.
sicorspa
Post by sicorspa » Mon May 12, 2014 1:02 pm
I'm trying TeeChart PRO Sourcecode Beta on Delphi XE6 Trial but trial version doesn't have command line compiler function. Is it possible to have the precompiled BPL files for VCL??
I have tryed to compile all manually, but I get a plenty of errors that makes it impossible to get a result...
Post by Narcís » Mon May 12, 2014 1:09 pm
We are about to publish the full maintenance release. Please stay tuned.
Thanks for your patience.
Post by Narcís » Tue May 13, 2014 8:25 am
The new maintenance release is now public. Here you have the instructions on how to use TeeRecompile via command line.
