hyperbole
strobbekoen
hyperbole
Post by strobbekoen » Fri May 16, 2014 5:30 am
I want to draw a hyperbole with the equation y = a + b/x
What would be the best way to achieve this ?
I thought of a TFastLineSeries with a TeeFunction y = f(x)
Then set the bottom axis min/max to the required range
Or is there a better way ?
Thank you
Re: hyperbole
Post by Yeray » Fri May 16, 2014 7:34 am
strobbekoen wrote:I want to draw a hyperbole with the equation y = a + b/x
Yes, this would be the way to go.
strobbekoen
Re: hyperbole
Post by strobbekoen » Sat May 17, 2014 10:28 am
Thanks for the help - here's the result
Re: hyperbole
Post by Yeray » Mon May 19, 2014 9:00 am
As always, your app looks amazing. 8)
Have you tried to activate GDI+? The lines will look smoother probably loosing some performance. Just a tip you've probably already tried.
