axis label abgles
axis label abgles
TeeChart offers many formatting possibilities for the individual diagram elements why it is sometimes a little bit difficult to find the right option. So the marking at the lower axis can be fixed in different angles. But only when angles from 0, 90, 180 and 270 are used, the marking text is readable because it is lined up at the beginning or the end of the text chain. If angles, e.g. of 45 degrees, are set, the text chains are aligned centrically to the tick and overlaid half of the diagram. Is there a possibility of adjusting the text chains of the markings at the lower axis at arbitrary angles so that there is no overlapping with the diagram?
- axis.jpg (136.63 KiB) Viewed 3929 times
Re: axis label abgles
Hello keulo6,
Thanks for your information. I would like inform you that the bug is known for us and it has been already added in bug list report with number ID742. Feel free to add your email account to the ticket so you want be automatically notified when and update arrives.
Thanks in advance,
Thanks in advance,
