Hi
I was looking for a solution to this... http://codeverge.com/embarcadero.delphi ... om/1091037 so upgraded from 2013.9 Pro to 2014.11 Pro and it looks like the problem still exists.
Is there any estimate of a fix? If at all.
Thx
MartinF
PS a brief description "The problem is not limited to date formats. When LabelsAngle>0 (I tried 45, 60 90) the labels of bottomAxis will go thru the axis.
I get the impression that the margins and padding do not work at the bottom. With LabelsAngle=0 and two-line labels, the bottom row will touch the border whatever I try with the margins and padding."
45 deg angle bottom axis issue
Re: 45 deg angle bottom axis issue
Hi Martin,
The following code seems to work fine for me here with TeeChart v2014.11 and XE5:
Could you please try the project attached to see what gives for you?
uses VCLTee.Series, VCLTee.TeeConst;
Chart1.Title.Text.Text:=TeeMsg_Version;
Chart1.View3D:=false;
Chart1.AddSeries(TLineSeries).FillSampleValues;
Chart1.Axes.Bottom.LabelsAngle:=90;
- testLabelsAngle.zip
- (1.57 KiB) Downloaded 325 times
