TeeChart Editor bug
GTI
TeeChart Editor bug
Post by GTI » Fri Dec 12, 2014 2:07 am
In desing time I was traying to change the default serie in a TChart Object using the TeeChartEditor form, when I tryed to change the serie, the next error message is displayed!
TeeChartEditor Bug
The same behaviour at runtime invocating TeeCharEditor component.
Re: TeeChart Editor bug
Post by Yeray » Fri Dec 12, 2014 9:08 am
What TeeChart version are you using? It sounds like this:
http://bugs.teechart.net/show_bug.cgi?id=753
GTI
Post by GTI » Tue Dec 16, 2014 6:13 pm
Yes thats de problem, We are using the installer TeeChar2014RADXE. I read in the posts that you bring an special exe, Do we need to reinstall teechart? , and where is it? :shock:
Post by Yeray » Wed Dec 17, 2014 9:16 am
The ticket B756 was closed the 2nd June 2014, as you can see in the ticket history.
So, the v2014.12.140923, released the 23th Sep 2014, should include the fix.
What version are you using?
GTI
Post by GTI » Sat Dec 20, 2014 1:05 am
The details of the installer that we downloaded are these:
Release Notes 12th May 2014
TeeChart VCL/FMX version 2014
Build 2014.11.140512
If I download the next realease :
TeeChart2014RADXE5.exe
September 24, 2014
Build 2014.12.140923
What are going to happen with my lincense? I did a manual registration, with a key that sales gave me. Could I use the same key when I reinstalled TeeChart?
Post by Yeray » Mon Dec 22, 2014 9:30 am
GTI wrote:What are going to happen with my lincense? I did a manual registration, with a key that sales gave me. Could I use the same key when I reinstalled TeeChart?
I see you ordered an upgrade from v8 to the actual TeeChart VCL/FMX with Sources the 6th October 2014. According to the subscription licensing, this license gives you access to any release within a year after the order, in your case unil the 7th October 2015.
So yes, you should be able to use your license key to download and install TeeChart VCL v2014.12.
