Polarseries draws unwanted line
gerhardsachs
Post by gerhardsachs » Tue Jan 20, 2015 6:39 pm
on the attached jpg it can be seen that the chart contains a line from the center of the circle at about 20°. This line is the first out of about 800 segments.
Before anything is drawn, I set the axis with the following lines, mb is 500.
SMEChart.LeftAxis.Automatic := false;
SMEChart.LeftAxis.SetMinMax(-mb, mb);
SMEChart.BottomAxis.Automatic := false;
SMEChart.BottomAxis.SetMinMax(-mb, mb);
The other attachment lists the values, I exported it using ChartEditor.
All radius values are close to zero, so where does the line from -500 to zero come from ?
Gerhard Sachs
messkurve.zip
(6.58 KiB) Downloaded 523 times
Re: Polarseries draws unwanted line
Post by Narcís » Wed Jan 21, 2015 10:02 am
Hello Gerhard,
After looking at your data file I see no explanation for that. Could you please attach a simple example project we can run "as-is" to reproduce the problem here?
gerhardsachs
Post by gerhardsachs » Wed Jan 21, 2015 8:24 pm
Hello Narcis,
here is the requested sample project.
It seems that the line is only drawn if the angle offset is not zero.
The project was compiled with Delphi XE7 using the latest TeeChart.
Regards Gerhard
PolarSeries Startproblem.zip
(75.78 KiB) Downloaded 523 times
Post by Narcís » Thu Jan 22, 2015 10:27 am
Hi Gerhard,
Thanks for the information.
I could narrow the problem down to the code snippet below and it looks like a defect to me, which I have added to bugzilla (ID1096). Please feel free to sign up at bugzilla and add yourself to the CC List to receive status updates on the issue.
uses TeePolar;
var
  Series1 : TPolarSeries;
  i : Integer;
  Series1:=TPolarSeries.Create(Self);
  Series1.Pointer.Visible:=False;
  Series1.Brush.Style:=bsClear;
  for i:=0 to 359 do
    Series1.AddPolar(i+10, 0);
  Chart1.Axes.Left.SetMinMax(-1, 1);
  Chart1.Axes.Bottom.SetMinMax(-1, 1);
  Chart1.View3D:=False;
  Chart1.AddSeries(Series1);
