With Upgrade cant find units.
INL2
Post by INL2 » Fri Mar 06, 2015 6:41 pm
I tried upgrading from 8.06 to 8.08 to see if it would fix a bug.
After uninstalling and then installing 8.08 it can't find several packages I use in a Form. (teCanvas, Series, TeePenDlg, TeeBoxPlot)
I unistalled 8.08 and went back to 8.06 and it works fine.
Is there something different you need to after the 8.08 install, the 8.06 didn't require anything special.
Re: With Upgrade cant find units.
Post by Yeray » Mon Mar 09, 2015 10:51 am
I'd recommend you to check the paths in your IDE after each installation to make sure they reference the correct version.
Also check a new simple project works fine.
If the packages and the paths look fine and a simple project also works fine but you still have problems with an old project, then I'd check the references in the project files manually (with notepad or similar).
