clicked part for axis
n2n
Post by n2n » Thu Jan 14, 2016 2:22 am
im trying to get the clicked part for axis, im using CalcClickedPart function, it works but if i click on axis labels it wont trigger. also protected AxisRect function is returning rect excluding the label part, if you look at my screenshot, it will only work if i click on the axis line but it doesnt work when clicked on labels.
Re: clicked part for axis
Post by Yeray » Thu Jan 14, 2016 5:01 pm
This should allow you to determine when an axis label has been clicked:
uses TeCanvas;
  function RectOf(AAxis: TChartAxis; Index:Integer):TRect;
  var tmpItem : TAxisItem;
    tmp,
    tmpW,
    tmpH : Integer;
    tmpP : TPoint;
    tmpItem:=AAxis.Items[Index];
    tmp:=tmpItem.LabelPos;
    tmpW:=AAxis.ParentChart.Canvas.TextWidth(tmpItem.Text);
    tmpH:=AAxis.ParentChart.Canvas.FontHeight;
    if AAxis.Horizontal then
      if AAxis.OtherSide then
        result.Bottom:=AAxis.PosLabels;
        result.Top:=result.Bottom-tmpH;
      end
        result.Top:=AAxis.PosLabels;
        result.Bottom:=result.Top+tmpH;
    end
         result.Left:=AAxis.PosLabels
         result.Right:=AAxis.PosLabels;
      result.Left:=tmp-(tmpW div 2);
      result.Right:=result.Left+tmpW;
    end
      result.Top:=tmp-(tmpH div 2);
         result.Left:=result.Right-tmpW
    if AAxis.ParentChart.View3D then
      tmpP:=AAxis.ParentChart.Canvas.Calculate3DPosition(result.TopLeft.X,result.TopLeft.Y,Round(AAxis.ParentChart.Width3D*AAxis.ZPosition*0.01));
      OffsetRect(result,tmpP.X-result.Left,tmpP.Y-result.Top);
var i: Integer;
  with Chart1.Axes.Bottom do
    ParentChart.Canvas.AssignFont(Texts.Font);
    for i:=0 to Items.Count-1 do
      if PointInRect(RectOf(Chart1.Axes.Bottom, i), Chart1.GetCursorPos) then
        ShowMessage('clicked label');
n2n
Post by n2n » Fri Jan 15, 2016 2:52 am
That method will get me the rect of each label, but i need to get the rect of Axis, just as shown below, if i use this method it will not trigger when user click on the gap between labels.
n2n
Post by n2n » Fri Jan 15, 2016 6:13 am
nevermind, i have managed to get the full rect based on first items left and last items right. thanks
Post by Yeray » Fri Jan 15, 2016 9:27 am
I'm glad to hear you found how to achieve it.
