Bottom Axix DateTime increment
Torez
Post by Torez » Fri May 06, 2016 4:25 am
Hallo All,
My application is adding points to chart every second or twice a second.
Requirement is to have actual DateTime stamp on every point. Currently
I am struggling with Bottom Axis label. Bottom label format is :
dd/mm hh:mm:ss
and I can see this format on the chart. But when application add points every second
      YValue := SomeValue;
      XValue := Series1.XValues.Last+1;
      Series1.AddXY(XValue, YValue);
increment is on Day field, not Second field. I have tried to initialize increment via
Chart1.BottomAxis.Increment := DateTimeStep[dtOneSecond]
and it does not work. I can work around this problem by simply doing:
      YValue := Sin(DegToRad(ValSin)) * 300 + 450;
      XValuTime := FormatDateTime('dd-mm hh:nn:ss', Now );
      Series1.AddXY(XValue, YValue, YValueTime);
but problem is, once chart is saved to file and imported back, time values
are gone.
Can you please advise what to do ?
regards,
Tomas
Torez
Re: Bottom Axix DateTime increment
Post by Torez » Fri May 06, 2016 4:28 am
oh, there is typo, didnt check it. Should be:
XValueTime := FormatDateTime('dd-mm hh:mm:ss', Now );
Series1.AddXY(XValue, YValue, XValueTime)
Post by Yeray » Fri May 06, 2016 1:55 pm
I've done a simple example trying to reproduce this. I'm using directly TDateTimes in the XValue array instead of using the series Labels, but it seems to work fine for me here:
uses Series, DateUtils;
var fastLine1: TFastLineSeries;
var i: Integer;
    tmpDate: TDateTime;
  Chart1.View3D:=False;
  Chart1.Legend.Visible:=False;
  fastLine1:=Chart1.AddSeries(TFastLineSeries) as TFastLineSeries;
  fastLine1.FillSampleValues(100);
  fastLine1.XValues.DateTime:=True;
  tmpDate:=Now-DateTimeStep[dtOneSecond]*100;
  for i:=0 to fastLine1.Count-1 do
    tmpDate:=IncSecond(tmpDate);
    fastLine1.XValue[i]:=tmpDate;
  Timer1.Interval:=1000;
  Timer1.Enabled:=True;
  Chart1.Axes.Bottom.DateTimeFormat:='hh:mm:ss';
procedure TForm1.Timer1Timer(Sender: TObject);
var XValue, YValue, tmpDiff: Double;
  tmpDiff:=fastLine1.YValues.Range/10;
  YValue := fastLine1.YValues.Last + random*(tmpDiff) - (tmpDiff/2);
  XValue := fastLine1.XValues.Last+DateTimeStep[dtOneSecond];//1;
  fastLine1.AddXY(XValue, YValue);
Torez
Post by Torez » Sat May 07, 2016 9:47 am
Hallo Yeray,
thank you for answer. DateTimeStep[dtOneSecond] was missing point and some mess in my Chart.
Now is everything working.
But I have ome more issue. Smallest TDateTime step is dtMilliseconds and then dtOneSecond.
Its possible to define 250ms and 500ms as I want to speed up sampling time. I can not figure
out how to define DateTimeStep to 250ms. Please advice.
BR
Tomas
Post by Yeray » Mon May 09, 2016 8:30 am
Hello Tomas,
Torez wrote:Its possible to define 250ms and 500ms as I want to speed up sampling time. I can not figure
Changing a couple of lines in the code above seems to work fine for me:
  tmpDate:=Now-DateTimeStep[dtOneMillisecond]*250;
  Timer1.Interval:=250;
Torez
Post by Torez » Sat May 14, 2016 8:42 am
Hallo Yeray,
great, thank you for answer. Things are easy once you have broad perspective :o)
Tomas
