Possibility to hide some tools
mpic
Post by mpic » Fri Nov 18, 2016 1:47 pm
we are wondering, if its somehow possible to hide some of the graph tools in the ChartEditor Form. If I make a new project with just one TChart and a TChartEditor pointing on that TChart and a button to call the ChartEditor1.Execute, I can select the "Tools"-Tab. If I then press the "Add" button, I have a lot of possible tools to choose from (Series/Axis/Other). But for our purpose, most of the tools are somehow unnecessary and we would like to hide these tools from the user. I didn't find a way to configure, which tools are available to the user and which are not. Maybe you can give us a hint? Is this possible at all?
Thank
Christian
Re: Possibility to hide some tools
Post by Yeray » Mon Nov 21, 2016 4:07 pm
Hello Christian,
Note the editor is designed to help the developers to build and test their applications, not to be accessed by the final users, so we don't recommend giving access to it.
Also note that owning the sources you can modify them - including the editor - to fit your needs.
